08-14-2006, 12:36 PM
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Originally Posted by ScottD
Yep, the T1 and T2 exhaust manifolds are different, you'd have to dremel or machine off the top of the manifold where the turbo bolts to it. I know this description isn't good but basically that's what you'd need to do.
using a Dremel to make this notch would be RIDICULOUS; at minimum you need a 4" angle grinder or bench grinder; a die grinder would work but would take a long time ... there is A LOT of material to remove
you don't need the notch on the exh mani (or accompanying notch on turbo turbine housing) UNLESS you need the clearance for a late-TI/TII 'one-piece' or a TII 2-piece intake mani ; if you have the early-TI 'log' intake mani then you can swap the TII turbo without any clearancing required; it will bolt up to your "TI" exh mani no problem
if you swap the TII turbo on your TI log car, you should swap the compressor housing from the TI turbo onto the TII turbo (then you can sell the TII compresor housing) OR be prepared to do some custom plumbing to match the TII outlet to the log intake mani inlet
OR swap a late-TI one-piece intake at the same time (and update electronics to match) hell may as well add an IC too and do the full TII conversion
