02-07-2008, 11:25 AM
Whats this worth?
My Ride: 87 GLHS #208
Engine: 2.2L tII
You are looking at a beautiful and rare Shelby Charger GLHS. There were only 1000 made in 1987 and this is number 0208 and all the Shelby Parts are still there. The car still wears it's original paint and still has a nice shine to it. There are a few chips, a couple of faded spots and one small ding on the car. The interior is in perfect condition with no rips or tears. The bottom of this car looks like it just came from the assembly line...there is not a speck of rust and all the original primer is there along with a few markings from assembly. The car originally came from Franklin, Tennessee and I have all the original books, original window sticker, the keyfob from the assembly plant in Michigan, the key tag from the dealer lot and even a copy of the cashiers check from the original purchaser. Everything on this car works including the A/C and can be driven without any issues, nothing needs to be done.
Now on to the modifications that have been done:
Freshly Rebuilt TII Bottom End with Weisco Forged Pistons, ARP Rod Bolts, ARP Main Studs and ARP Head Studs
Ed Peters Oil Pan
Steve Menagon Fully Race Ported Head with Large Valves
TII Roller Cam
2 Piece Intake with Large Throttle Body
Turbos Unleashed Header
Turbos Unleashed Braided Turbo Lines
Turbos Unleashed 2 Stage GLHS Computer
Turbos Unleashed T3/T04E TrannyBuster Hybrid Turbo 57 Trim w/.63ar
Tial 38mm External Wastegate
Tial 50mm Blow Off Valve
3" Exhaust Front to Back
Custom Front Mount Intercooler
Custom Intercooler Piping
Auto Meter Gauges
525/555 Transmission with AN ULTRA RARE SHELBY DIFF
McLeod RevLOK II Clutch
Rear MP Sway Bar
Cross Drilled Front Rotors
Stainless Steel Braided Brake Lines Front and Rear
Full Polyurathane Bushings on the Entire Car
On the Dyno this set-up made 305 HP to the wheels at 20psi on pump gas with over 280 tq.
