09-26-2006, 01:49 PM
#23
Yeah as of now, i can make the 11th def. If I get my boost under control I might even run the car... My g-valve isn't cooperating right now, if disconnect the line to the WG, I get 22psi that my cal is setup for, but I don't want to run that much. I have an ebc I will be putting in, might work better. We shall see.
Jen- If you guys go, I might be able to meet up with you on the way down or something. We can work it out later though.
