11-08-2007, 07:09 PM
#16
Re: TurboChryco CT MA RI Dyno Day GTG saturday 11-17
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
Ok come on by at 10am for some coffee and donuts!
Anyone else?
:banaride:
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
11-10-2007, 05:50 PM
#17
My Ride: 92gtc vert
Engine: 2.5 8v
BUmp!
11-11-2007, 07:35 AM
#18
My Ride: 89 Daytona Shelby
Engine: 2.5L
if i cure my oil pressure issues.... i'll have the car there. if not i'll still go but in my other "reliable" car.
Scotty
89 Daytona Shelby T-top - 2.5"T2", ST springs, KYB's, 11psi, no more smoke!!!
96 Pontiac Grand Prix SE - 3100, everything a GTP but the drivetrain and wheels...
11-11-2007, 11:39 AM
#19
My Ride: 92gtc vert
Engine: 2.5 8v
Sure all brands can go. throw that thing on the dyno!
what oil issues?
11-11-2007, 02:33 PM
#20
Engine: 2.5L
oil issues... well i've been experiencing some psi drop when real hot. the pickup got plugged up with some silicone. i replace the pump, cleaned the screen, and opened up the pick up. now the oil light dont come while idling which is good. but i think the damage has been done. its not making any noise or anyhting, just low psi when hot. just means i may build another shortblock during the winter. granted i just rebuilt the motor about 5k and almost 2 years ago but this has been a learning experience for me. so far so good, i'll prolly take it anyway just means i just gotta paypal my spot soon....
as for tossing the GP on the dyne, its a stock stock 3100 with nothing done at all. i could go for the LOWEST hp numer of everyone with that...
Scotty
11-11-2007, 07:19 PM
#21
My Ride: 92gtc vert
Engine: 2.5 8v
Check your sending unit and connectors, I had similar issues and it ended up being a lose connector.
After replacing pump and bearings...
11-12-2007, 08:03 PM
#22
Engine: 2.5L
new sender... clip is good, that part of the harness came from the old car... who knows... anyways, anyone else plannin to run???
Scotty
11-12-2007, 08:18 PM
#23
My Ride: 92gtc vert
Engine: 2.5 8v
Trying to get confirmation from others. Weather looks good:
Daily Weather Forecast for Bristol, CT - weather.com
throw a cheapo mechanical gauge on there and see what you really got.
11-12-2007, 10:12 PM
#24
Still around, just workin
My Ride: 87 csx # 175
Engine: 2.2 T III 16V
Well my car won't be ready  I'm planning on a first start this week, BUT
I still need to plumb the turbo to I/C to the TB and I still need to figure out how i'm gonna fit the rad inthere with that big ass intake mani.. and still need rad fans..anyone gotta VW schirocco rad hanging around that has a good fan? and a couple fittings for the fuel pressure gauge is about it..SOOO close to being done  just about done with the electrical  looks like I'll have to do the dyno another day.. I'll be sure to video it anyway.. None the less, I'll most likely be there to support everyone and help out if needed..
I would dyno the r/t but its got real bad blowby on cyl4 so thats a no-go..
Faster than a speeding ticket!!... someday
1987 SHELBY CSX #175 TIII POWERED ALL OUT DRAG, Possible street duty again?
1991 SPIRIT R/T TIII stock and i popped the headgasket..
11-12-2007, 11:38 PM
#25
My Ride: 92gtc vert
Engine: 2.5 8v
Cool Joe see you there, maybe you can make a final mad dash!
I was just playing with mine getting it ready. That S60 turbo sure pushes a ton of air. I was playing with the idle and fixing up a silicone hose I popped(it had a pin leak, bubbled up the layers and burst). Tie wrapped some vac lines that kept popping off. My alternator belt need tightening. My iddle is still a bit lean at 15.6ish on the wide band. I seem to be running too rich and turned down the fuel pressure. I can only pull to 5200. My cal still has that rev limmit set somehow. It would also not read a gm 3bar map, just sputters and dies when I plug it in. Its gonna be fun to see what I pull at the dyno. I will play a bit more with it over the next few days.
11-13-2007, 11:24 AM
#26
My Ride: 90 Shadow VNT comp
Oil Pressure on an 8v will be 50-70psi cold and will drop to 8-12psi when fully warmed up..
bill baker
NE pres
90 shadow 12.25@116mph
11-13-2007, 01:25 PM
#27
Mo' valves, mo' boost
My Ride: Daytona
Engine: 2.4L DOHC
Damn, I'd love to go to this, even just to watch. Chances are I won't have the 2.4 running by then though.
Jon J.
1989 Daytona 2.4L - MPH
2003 Neon SXT - MPG
11-13-2007, 01:59 PM
#28
My Ride: 92gtc vert
Engine: 2.5 8v
Hey you are not too far, come on down. Maybe even put your daily driver on the dyno.
11-13-2007, 05:02 PM
#29
Engine: 2.5L
sir, thank you very much for the info. thats about where i was with the old pump with a gauge attached. least i know im still within spec. welp, now to turn it up from 11 to 14...
Scotty
11-13-2007, 09:11 PM
#30
My Ride: 92gtc vert
Engine: 2.5 8v
Good to see you are looking good. Looks like more expectators coming than cars.
