11-15-2012, 06:45 AM
#2374
Re: MNSDAC "Minnesota" meeting
TD Hardcore User!
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
The parts books are all messed up for these cars as well as aftermarket wiring diagrams. For example, in 1991, if you specify that you have 15" wheels for the car, you are going to get the 11" brake parts, when in fact the wheel size has no correlation to what the car is supposed to get. If you want the small brakes, you must specify 14" wheels regardless of actual wheel size(my Lebaron has 16" wheels with small brakes from the factory). If you have 15" steel wheels, the bigger brakes will not fit inside the rim, so go figure. If you specify that you have rear disc, you get the big brakes when in fact if you had solid rear discs, you have the smaller brakes. If you have VENTED rear disc, then you have the big brakes, but the computer never asks if you have solid or vented.
So, yes, things are messed up. The last 1990 model I junked out, I was going to take the brake setup off of it, but I couldn't since it was still the old(er) school suspension setup.
