09-28-2009, 10:10 AM
Neon vs Daytona vs Shadow
My Ride: '84 GLH, '04 R/T
Engine: 2.2 HO, 2.0 Magnum
The contenders:
JR 180lb
1996 Dodge Neon 4door
roughly 50,000 miles on a rebuild
2.0 SOHC 5spd 3.55fd
Crane 12 cam
K&N intake
MPx 55mm tb
MPx UDP
FastFabs longtube header
no cat, 2.25'' pipe into Magnaflow muffler
No AC No PS
Marty 240lb(fat kid)
1991 Dodge Daytona IROC
150,000 miles
2.5 T1 5spd 3.87fd
T2 IC and rad
2 piece intake mani
homemade cold air intake
gvalve set at 13psi
2.5'' dp into a 3'' side exit no cat no muffler
Ned(Me) 250lb(fat kid)
1991 Dodge Shadow ES Convertible
175,000 miles
2.5T1 5spd 3.77 fd
T2 IC and rad
MP stage 1 cal
gvalve set at 12psi
stock exhaust
All the runs were done from a 1st gear roll. 1st was the neon vs IROC. The Neon had no passengers, the Daytona had the me and Marty in it. Every one was dead nuts even until the end of 3rd gear when the IROC started pulling slowly on the neon. Needless to say I was VERY impressed with the Neon!
Next comes the Shadow vs the Neon. The first two runs it was me and Marty in the Shadow and JR still alone in the Neon. The Neon pulled a solid length and some change by the end of third! WTF?! So I then stuck Marty in the Neon with JR to balance the weight a bit. Next two runs my Shadow put about a length on the Neon by the end of third! Once again, very impressed by the lowly Neon SOHC!
We didnt get a chance to run the IROC and the Shadow because the MAP on the Tona crapped out. However I believe the IROC will handily whip the Shadow as is.
Now JR wants a MP ecu, ICEMAN intake, and a 3.98fd trans for his neon. Marty wants to go with a Cal, +20s, and about 18psi! Im getting a 2.5'' catback for the Shadow this weekend, but Im gonna wait on a fresh engine and a bigger turbo before I go for more boost!
