Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > General > At The Strip
At The Strip Have some numbers from the track, post them here.
Old 10-24-2004, 10:15 PM   #1
My T1 log no i/c new record 12.998@104.33
My Ride: 85 GLH
Thats right , I finally hit 12's and I know there is more it. This was the first pass off the trailor with the zener diode, but it was still poping /detonating so I switched to a super cold plug but I had a horrible launch then missed 2nd and then it pulled so clean and hard that I actually had a higher mph with a 13.851 than the 12.9 pass. Unfortunatly I only got those 2 passes in so hopefully this Thursday I'll get a little deeper in the 12's. This is still with original cast sluggo pistons running 20 psi on 110 leaded! I think its the fastest one in the world.
Bryan
turbodudehere is offline
Old 10-25-2004, 01:05 AM   #2
Thats amazing, great job! Can we have some info on the car?
Thanks,
Scott
dodgeomniglh is offline
Old 10-25-2004, 01:21 AM   #3
My Ride: 85 GLH
85 GLH T1, a555/Quaife, Center Force, custom axles,22''M/T slicks,Quickor front rear and side mounts, Koni's, Ground Control, Eibach, walboro pump,S60 cam, 803's, MP comp. MSD coil,Magnacore wires,open throttle body, 2 1/2 ex. MBC,zener doide,Fidanza adjustable cam gear.
Best ET 12.998, Best MPH 105.25 @20psi 16 degrees base timing, down pipe only. no passanger or rear seat.
Bryan
Old 10-25-2004, 02:52 AM   #4
wow your really going for that non IC log record pretty hard, that's awesome!!!
Instead of using 110 next time you should step it up to 116 if it is available to you. possibly more boost
89daytonaTII is offline
Old 10-25-2004, 08:48 AM   #5
Talking
My Ride: 85 GLH
Yea I will be turning up the boost, I'm not worried about blowing it up cause I have another motor to put in for a winter project. I can probably get some VP c18 from work, I believe it is 118 octane!!
Old 10-25-2004, 12:20 PM   #6
My Ride: 1986 Shelby Charger
Engine: 2.2 SOHC
Goin for the non-IC log rcord? Doesn't he already have it beat?
Bryan, good to see you back on here.
GLHandGTS is offline
Old 10-25-2004, 12:40 PM   #7
R/T
Registered User
What was the 60ft time???
R/T is offline
Old 10-25-2004, 01:58 PM   #8
yeah I guess. he *went* for it pretty hard then
Old 10-25-2004, 04:16 PM   #9
My Ride: 1986 GLHS #126
Engine: stock
great timeslips, good driving.
20 psi and no intercooler, you do have guts!
do you know your race weight?
i'd also be curious as to what your a/f ratio is under these conditions.
Marcus86GLHS is offline
Old 10-25-2004, 06:51 PM   #10
My Ride: 85 GLH
I dont have a A/F or EGT gauge yet, Im sure it wouldnt look good. lol
This are the 12.998 stats
1.851------60ft my best is a 1.834
5.394------330ft
8.293------1/8 @ 83.93mph
10.840-----1000ft
12.998-----1/4 @ 104.33
Old 10-26-2004, 12:07 AM   #11
You should look into geting water injection.
dodger is offline
Old 10-27-2004, 08:03 PM   #12
My Ride: 84 rampage
Engine: 2.2L T3
Nice run Bryan! What sort of tricks do you have lined up for the new motor?
Mike Radowski is offline
Old 11-01-2004, 12:12 AM   #13
My Ride: 85 GLH
Well I did it again!, new record for et and mph on 22psi
best et----12.804 @ 100.94 ,it started to miss about 100ft before the strip.
best mph--106.65 on a 12.839 pass.
All in all I had 15 passes in the 12's out of 28 runs. and it still drove up on the trailer!! I dont know why it didnt blow something up. Maybe I'll bring it to Turbopolluza.
Bryan
Old 11-07-2004, 04:49 PM   #14
My Ride: 88 Shadow
Feedback: (7)
You should get a 3'' TU swingvalve and 3'' exhaust! Try to free everything else up thats possible. And as somebody mentioned before some water injection wouldn't be a bad idea.
moparzrule is offline
Old 11-07-2004, 04:51 PM   #15
My Ride: 88 Shadow
Feedback: (7)
Oh and what are you doing as far as fuel mods to add fuel?
Online Advertising | Mortgage Calculator | Business Credit Cards | Buy Shares | MPAA
Page generated in 0.43072 seconds with 13 queries
