10-16-2008, 03:34 PM
Re: Turbo 3.0 playing on the streets
My Ride: '88 Shelby Z TII
IIRC the limiter not only cuts spark, but fuel also. So, if you are in boost, for that minimal amount of time the engine does go lean. In the end it all ads up. Not to mention that the limiter also adds and subtracts a LOT of energy in a very short amount of time, so it is in effect "hammering" the engine. Another thing to think about is that I know in the unstructions for my Devil's Own it says to avoid hitting the limiter while the alchy injection is on. More than likely this is to help avoid potential hydrolock(it very well *could* happen.
I suppose above all I simply don't like doing that to my engine. I only hit the limiter in my '90 *ONE* time...when I did it on purpose just to see what it would do, I NEVER did it again. The '92 Shadow I had I did it a couple of times due to missed shifts. I've never hit it in my '88. I dunno...I just try to avoid it becuase I know it's there for a reason and I also kow it's not a soft limiter, so it's kinda hard on the engine.
For the track, I'd suggest getting some sort of anti-lag control as that seems to be more of what you need. I personally don't like them for my car becuase of how hard ti is on the turbo, but for what you are doing, it is probably the right solution...
YMMV
