Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo specific > DSM
DSM Discussion for all things Diamond Star Motors
Old 04-08-2009, 12:50 PM   #1
Eagle Talon Turbo 97
My Ride: 92Daytonas/72Charger
Engine: 2.2 T3, 2.5 and 440
i have a few question about that 2.0 turbo engine.
I replaced hg not long ago, and im wondering if it would have been easier/faster to get the whole engine out of the car to do the job ?
Any trick to tighten the intake manifold to the head with the engine still in the car?? (suspecting a vacuum leak)
How to hook up a narrow air/fuel gauge (wich wire is what?) ?
kriss440 is offline
Old 04-08-2009, 01:58 PM   #2
Re: Eagle Talon Turbo 97
Going Hybrid All Around
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (13)
Moved to the DSM section, will probably get a better answer that way.
Which would you rather have, go fast goodies or shiny shoes?
Your feet may look good, but if your engine blows up, you ain't going anywhere.
1989 Dodge Daytona ES - T-top - 2.5l T2 with A555
1983 Dodge Rampage - 2.2l T2 with A525 (RIP)
1984 Dodge Rampage - 2.2l Carb with A525 (RIP)
1987 Dodge Shelby Charger GLHS #782 (RIP)
1987 Dodge Lancer ES - 2.2l T1 with A413 (RIP)
1983Rampage is offline
Old 05-13-2009, 03:48 PM   #3
My Ride: 93 Talon Tsi AWD
Engine: 2.0 4g63 turbo
This should help, and yes, it is wayyyyy easier to pull the motor. VFAQ Site - Visual Frequently Answered Questions
BadTXTalon is offline
Old 05-21-2009, 04:20 PM   #4
My Ride: 86 glh omni
Engine: 135
Feedback: (-1)
Images: 18
On the 90-94 dsm there's a o2 senser wire on the paaenger side of the car right by the kick panel and you just tap into it. It's either white or gray and the vfaq with give you more details. I would just leave the motor in the car because I've seen my buddies do it all the time and it's almost as easy as a td head 30-35 mins
boostedhatch is offline
Old 05-21-2009, 04:42 PM   #5
Here's a how to link:
Finding the O2 Sensor Wire
It works great.
Old 05-23-2009, 07:08 AM   #6
My Ride: 05 Evo 8
Engine: 2.0
If your notch the powersteering bracket a little bit and remove the support bracket on the back of the intake manifold you'll be able to remove the whole top end of the motor without disconnecting the exhaust manifold or intake manifold. Removing the bracket behind the intake manifold cleans up all kinds of room out back there
OmniDreams is offline
Old 06-04-2009, 12:50 PM   #7
Pulling the head isn't that bad at all. It takes way more time to pull the whole engine, easier yes, but more time consuming.
Narrow band o2 gauges are useless and stupid. Go wideband or don't bother.
Thunderbisciut is offline
Old 06-04-2009, 01:34 PM   #8
Dsm af setup is fairly easy, and wayyyyyyy cheaper than switching to a wideband. THough I agree wideband is superior in every way but price. I went with the middle ground, egt gauge/ borrow someones wideband sometimes ;D
Old 06-04-2009, 02:04 PM   #9
EGTs are pretty useless too. For the price of an EGT gauge and a narrowband gauge you can get a wideband, and actually tell what's happening. Ultimately a narrowband works the same way on every car, so saying the dsm af setup is easy is meaningless. The bottom line is chuck the narrowband gauge, and spend 180 on a wideband. Or even troll Ebay for a used one. They are nowhere near as expensive as they used to be, and there is no excuse not to have one if you're tuning. It's like trying to take someones temperature with your hand, you may be able to tell something isn't right, but you have no real idea.
Page generated in 0.17226 seconds with 9 queries
