02-27-2011, 07:47 PM
#47
Re: Daytona 2.5 to 3.3 Swap
My Ride: 1994 Lebaron LX
Engine: ∴ 6G72 12V
Nice, having the newer 90's cars makes things a lot easier.
being they didn't make 89 and older 3.3s the cars to use need to be 90 and later so the 90 later mounts are all the same. Putting a 3.3 in an older car would be a fab fest
It's not that bad, an early 3.0 passenger mount and the front mount from a newer K-based car should alleviate those problems. The wiring harness from a 1990 Caravan still uses the old school equipment so using that harness in my 88 Daytona seems to be very effective.
Ever think about doing a manual trans 3.3/3.8? The 2.7 manual stratus trans would bolt right on all you'd need is the 2.7 flywheel for the tone ring on the crank sensor.
Custom axles would be the issue as the outer splines used in the NVT-850 (2.7 5 speed trans) are from some oddball diesel application in Europe that Chrysler modified to work on the 2.7L V6. You would also have to probably use a Neon shifter as the cables are probably different and modify your clutch pedal to be a hydraulic one. I might consider doing it way down the road. Availability of NVT-850s is also an issue as Stratus 2.7L R/Ts and Sebring GTC 5 speed convertibles are fairly rare.
Here are some pics so far.
Awesome, you are really burning right through this swap. I better hurry up and get to the boneyard so I can catch up hehe. Looks like it came that way from the factory. Hope to see more people catch onto this swap. The 3.3L is quite the stone axe in reliability.
ϟϴĦ☾﹩℘øя⊥ṧ ⌨℠
