Old 11-19-2005, 10:37 AM   #1
GLHS837 leak tester V3
Bought the parts from Lowes this morning using GLHS's parts list.
With the exception of a few parts.
I bought a rubber elbow, and eliminated the glue and rubber connector.
rubber elbow = #1191801817 $5.49
connector = $.93
plug = $.58
tire valve(from Wally world) $2.85
Total = $ 9.85
Don't know how to get it any cheaper/easier than that.
Hardest part was talking my wife into letting me stop at WalMart.
Now to try it out.
Keith Alto is offline
Old 11-19-2005, 11:17 AM   #2
Yep, best yet My Lowes was out of those elbows in 2 inch when I went And I had slight concerns about the elbow taking 20 psi. Most likely I'm paranoid
GLHS837 is offline
Old 11-19-2005, 03:35 PM   #3
Turbo outlet was so loose, I'm not sure how it stayed on.
Same for the IC hot side.
I installed stage 2 w/o toys a month ago, and my impression was, eh.
Would hit 15 psi and drop like a rock.
Now it holds 15 psi all the way to redline.
It destroys the tires in second gear. If you haven't checked the
hoses, do it soon.
Thanks GLHS, for the parts list.
Old 11-19-2005, 04:58 PM   #4
15 in these temps seems dead on. Come spring (or a trip to FL) you should see about 16-17. Should just hit target boost and hold.
GLHS837 is offline
Old 12-01-2005, 06:32 AM   #5
GLHS,
I tested last night to see if I could find the limit to the rubber hose.
At 18 PSI, as usual the Mopar BOP was leaking, but also my
#1 injector was leaking too.
Ever had this when testing?
BTW, the rubber hose started to straighten out a little, but it held
no problem. Not sure about 20 PSI.
Thanks!
Old 12-01-2005, 08:43 AM   #6
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
There is one way to get it cheaper than that. All you need is one rubber cap for 2" pvc pipe. It will actually be 2.5" ID. Slip that over the compressor inlet. Run your compressed air into the green vacuum line to the compressor housing, and pressurize the system. Done. Total cost under $3
contraption22 is offline
Old 12-01-2005, 11:15 AM   #7
good one mike, i was thinking also, using ur factory hose that runs to ur air box, just getting a plug for it.....
lil4drturbo is offline
Old 12-02-2005, 09:57 AM   #8
nemiro's Avatar
My Ride: 2005 SRT-4
Engine: 2.4L Turbo
I made a variation of this v3 tester last week. It has a male air compressor hookup, rather than the tire valve, and did use the rubber street elbow. I ran it at 20 psi regulated, and found that my stock BPV was leaking, the catch can connections were leaking, and so was the hot side IC connection. Fixed all that, and the car is much quicker to spool. Thanks to all who figured this out. I like having more tools in the garage
nemiro is offline
Old 12-03-2005, 02:14 PM   #9
Kieth, I would pull that injector and check the O-ring. Neil, thats why I used the threaded cleanout plugs. I have one cap with a tire valve, and one with a male air fitting.
GLHS837 is offline
Remortgages | Loans | Mortgage | Debt Consolidation | Cool Gadgets
Page generated in 0.32561 seconds with 14 queries
