Old 12-07-2005, 05:24 PM   #16
what is the difference between 2 bar and 3 bar?
Oni Snake is offline
Old 12-08-2005, 04:15 PM   #17
1 bar (-14.5 psi), 2 bar (30 psi), 11 bar (160 psi)
lil4drturbo is offline
Old 12-08-2005, 04:37 PM   #18
No, what is it?
I've heard of these MAP sensors, but dunno what they are.
Old 12-08-2005, 04:53 PM   #19
xtz
need one to run high boost calibrations. the map sensor tells the computer what boost the engine is seeing and how to compensate with fuel based on all the other inputs.
calibrations are designed around the map sensors readings, and 3-bar map sensors have different voltage output than 2-bar, same psi would register different voltages between the two map sensors. if you ran a 3-bar sensor on a stock cal, it would run like crap. so when you want to run high boost, you design the whole system for that purpose - injectors, calibration & map sensor, turbo/intake/exhaust should all be matched - if you want it to run right.
xtz is offline
Old 12-08-2005, 04:54 PM   #20
ooo, ok. That makes sense. thanks
Old 12-08-2005, 09:22 PM   #21
thanks xtz, could not have said it better myself!!
Bad Credit Mortgage | Online Advertising | Credit Cards | Best Credit Cards | Loans
Page generated in 0.42510 seconds with 13 queries
