12-05-2005, 04:52 PM
http://www.srtforums.com/forums/show...7&page=1&pp=15
With 17psi I'm looking at damn near what he's after.. 250-270 depending on boost. Right? Or am I wrong in my assumptions of power?
For less than $300. Should I be worried about something? Should I regap the sparkplugs. Do I need a larger IC, etc. What else do I need to do to run safely? Or is 17 psi completly safe by itself?
I'm not looking for much, just a little more fun out of the car cheaply and safely.
I plan on getting a DP with a dumpout, will I run into problems with the boost being 17 and switching over to the dumpout?
12-05-2005, 07:00 PM
My Ride: SRT-4
Engine: 2.4L
Okay here. I have a S2 WGA (from the Mopar kit.. but I have JUST the WGA) and a DP with a cutout (like the one you want.)
I made 261whp and 283wtq on the dyno this past spring, without resetting the computer. After resetting the computer, my horsepower numbers were about the same but I put down 303wtq! I've got massive boost spike but aside from that, I was happy with the first numbers!
The only thing I'm not happy is the inconsistency. The stock computer will pull my boost down to 15psi after a few WOT pulls after resetting the computer. I think it's just a matter of making sure that the WGA is set correctly in order to smooth out my boost spike/PTB issues.
But again, you can't argue a 30whp and 20wtq gain from roughly $350.
12-05-2005, 07:07 PM
My Ride: SRT-4
Engine: 2.4L
((What's with the forum not letting you edit after 5 minutes?))
Anyway. You're safe. No, you don't need a bigger IC. No, I don't think you need to regap your sparkplugs. As for going with S1, I'm not sure. I thought I read somewhere that if you go with S1, it will pull more boost than S0. I'm not completely sure though; I'd have to do a little bit more research.
Plus, if you're in unsafe territory -- the computer will pull boost and dump fuel until you ARE in safe territory.
After adding the WGA I was scared that the higher boost levels would cause me to run too lean. But my AFR was off-the-charts rich for a majority of the pull -- so yeah, I'd say you're safe.
12-06-2005, 11:23 AM
#12
My Ride: SRT-4
Engine: 2.4L
Originally Posted by Oni Snake
nice, thanks you two.
This is my first "my" car, and first car I'll be adding power to. So I'm slightly nervous about flucking things up.
I've got the solenoid..now I need the voltage switch and the boost controller..woohoo
Mine too!
