Old 04-12-2006, 09:53 PM   #1
This will end the IC debait 100%
My Ride: 2003 Silver SRT-4
Engine: 2.4
http://www.aeroforcetech.com/SRT4tech.html
Now if someone used this gage and did the intire FMIC swap. Same day, at operation temp this should prove what IC is the best IC and what are the cooling temps.
RPM
MPH
Intake Air Temperature
Engine Coolant Temperature
Injector Pulse Width in msec.
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure (vacuum/boost)displayed in PSI
Ignition Advance
Knock Retard
Throttle Position Percentage
Engine Load
2 user configurable analog inputs**
FrankNbeans is offline
Old 04-13-2006, 06:54 AM   #2
I see your in on the group buy.
I expect a full report!
Keith Alto is offline
Old 04-13-2006, 09:36 AM   #3
nice, this is exactly what I'm looking for. I may end up buying a couple at some point.
Oni Snake is offline
Old 04-13-2006, 01:28 PM   #4
Engine: 2.4
Yeah.. i will see what i can do... Want to compile some numbers up and get an average on everything. This would be 100% effective to find out what one is the best IC. No way you can dispute these numbers.
Old 04-13-2006, 07:06 PM   #5
Actually I'm not so concerned with the IC's, just how well the guages work.
Old 04-15-2006, 02:56 AM   #6
Engine: 2.4
I am sure the gauges will work just fine. He has done them for GM cars already. Really all it is, is a DAB tool shuved in a gauge pod. Plugs right into the port.... really can't see it going wrong.
Old 04-15-2006, 11:18 AM   #7
My Ride: 05 SRT-4, 98 S70 T5
Engine: A855, B5234T3
I'm tired of seeing people trying to determine what intercooler is better by using a chassis dyno. At least now air intake temps can be logged in a real driving scenario.
njshift is offline
Old 04-16-2006, 10:30 AM   #8
My Ride: 86 GLHS #163
Images: 123
Not really, because there are many other factors other then just intake air temp. There's things like pressure drop, CFM(how much air it can flow), and so on. Furthermore, things like boost pressure and ambient air will also effect the intake air temp.
The correct way to end the intercooler debate is to take them all, one of each, and gather data in a wind tunnel where you can control the variables. They would all be working in the same temp, same humidity, with the same charge air temp and same charge air pressure. Then you could monitor exit temps, pressure drop, and CFM all at once, and then compare.
sy2206 is offline
Old 04-16-2006, 11:02 AM   #9
My Ride: 86 SC & 98 Neon
1/4: 9.900
Although I'm building a SRT 2.4 motor for my Neon race car, I'm not up on SRT4 IC options.
With that said, the best IC is not necesarily the one that cools best. If it restricts flow but cools really well, then it's not better.
I've found that the most important factor about ICs is heat soak. If you have a massive IC and precool it with a fan, it will stay relatively cool while you're under throttle (at least for some period of time). It's more important (especially for drag racing) to dedicate a fan to pre-cooling the IC. If you have a really good IC that is heat soaked to the temperature of the engine compartment, you will not get much cooling effect from any IC.
The next important issue when choosing an IC is to make sure it does not restrict flow.
DblTrbl is offline
Old 04-16-2006, 11:25 AM   #10
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
How will this device read boost properly if the MAP sensor has been changed to a 3 bar, or a MAP clamp is being used?
contraption22 is offline
Old 04-16-2006, 03:24 PM   #11
Engine: 2.4
not sure.. have to talk to the guys making htem.
Old 04-16-2006, 08:03 PM   #12
Since it reads off the OBD info feed, not raw sensor data, it should be fine, Mike.
what voltage the PCM reads should be irrelevant, it'll output that data in normal form.
GLHS837 is offline
Old 04-16-2006, 11:18 PM   #13
Engine: 2.2 Turbo
Ok I understand. So if if the car is upgraded to S2 or S3, it will still read correctly, however to those using MAP clamps, it will be innacurate.
Old 04-17-2006, 06:00 AM   #14
Yep, GIGO
GLHS837 is offline
Old 04-17-2006, 07:39 PM   #15
I've been thinking.
Where are you mounting this guage?
Does somebody make a single guage pod?
I don't think I'd use any more guages than this one.
Credit Cards | Mobile Phone deals | Equity Release | Mortgage Calculator | Credit Cards UK
Page generated in 0.46059 seconds with 13 queries
