01-01-2008, 03:49 PM
Re: SRT4 engine and A555 tranny?
My Ride: 85 glh
they sort of bolt together. the two upper holes line up, nothing else does. i modified the stock omni mount to bolt to the 2.4 block to add another pickup point, and I still need to make a rear brace. you have to use the small starter and it will take a little grinding off the block and starter to make it fit...one of the oil drains is in the way. I ground the screw on the starter about flat. i don't know about stock manifolds, but I have no problems with an agp manifold.
