Old 01-31-2008, 01:10 AM   #1
spring mod
My Ride: 2004 srt 4
i was wondering how to preform spring mod on a stock wastegate, and do you by the spring , if so where can you get them?
spooled28 is offline
Old 02-12-2008, 11:56 AM   #2
Talking Re: spring mod
My Ride: '05 SRT4
Engine: 2.4L turbo
This is really easy (and CHEAP!) to do. You need a spring (throttle return type) that attaches to the WGA arm on one end and a solid mounting point (I used the battery tray) on the other. That's it. The amount of boost increase that you will be able to hold depends on the spring's pressure (you'll need a boost controller of some type to increase boost). Works OK but when you can afford it I'd step up for an AGP WGA.
MiniHemi148 is offline
Old 02-12-2008, 11:20 PM   #3
Re: spring mod
My Ride: 2004 srt 4
purchased a mopar stage 2 accuater, and a manual boost controler, going to install as soon as the ****ing weather warms up allitle, thanx for info
Old 02-13-2008, 06:49 PM   #4
Re: spring mod
My Ride: 91 Daytona
Engine: 2.4
we got my buddys car to spike at around 23 psi, and hold 20/21. only problem is the car learns, and starts dropping boost off sooner. we wired the PCM fuse to ignition power, so it reset everytime you shut the car off.
Rock Kustoms is offline
Old 02-13-2008, 08:21 PM   #5
Re: spring mod
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
VERY bad idea. You'll lose adaptive fuel and everything else that a complex adaptive engine managment system like the NGC controllers do. Simply disconnect the wastegate from the stock WGA solenoid, problem fixed. You'll get a CE/Code for part throttle boost exceeded, but that's minor. Use a MBC connected right to a manifold pressure source and an external spring or higher tension actuator to control boost.
90TurboVan is offline
Old 02-18-2008, 09:14 PM   #6
Re: spring mod
My Ride: 91 Daytona
Engine: 2.4
dunno, cars been gone for over a year now
Cheap Car Insurance | Mobile Phones | Cheap Loan | Modded Xbox | Cheap Loan
Page generated in 0.29954 seconds with 13 queries
