02-10-2008, 12:42 AM
Re: Any compatible flexplate for neon srt4 ?
My Ride: '04 Dodge Neon SRT-4
Engine: Chrysler A855 2.4L
There is no flexplate that I know of that will be better to use.
What's the main problem you've been running into, anyway? If I had to guess, I would assume the bolt holes are becoming oblong shaped in the flexplate? If that's the case, the root cause of the problem lies within the flex that occurs during high rpm clutch disengagements. The flywheel portion of the modular clutch assembly smacks into the crankshaft bolts, and the shock from that knocks the crank bolts loose. Soon, there are enough bolts loose enough to allow the flexplate to rattle around on the crank journal, causing the oblong shaped bolt holes.
I've had this happen to me twice as well. The only "real" solution to this is to go non-modular. You won't have to pay 650 for a non-modular setup. Just buy a Fidanza flywheel (usually around $350), and you should be good to go. I did this with my clutchmasters S4 clutch, as well as the Mopar performance pressure plate, CM 6-puck combo I used to run. It works just fine, and also reduces rotational mass.
