stratus 2.4l timing belt snapped? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
2.4l Turbo Discussion of the 2.4l turbo
post #1 of 11 Old 09-29-2008, 08:28 PM Thread Starter
TD Hardcore User!
My Ride: 87 GLHS
Engine: 2.2l turbo
hey are the 2.4l in the stratus (2000 i think?) interferance engines? also has anyone done timing belt on them ?
sleeperspirit is offline
post #2 of 11 Old 09-29-2008, 08:42 PM
My Ride: Starion
Re: stratus 2.4l timing belt snapped?
yep, time for new valves. and the cause of your belt breaking was probably due to the waterpump locking up.
pobort is offline
post #3 of 11 Old 09-30-2008, 08:22 AM Thread Starter
TD Hardcore User!
My Ride: 87 GLHS
Engine: 2.2l turbo
its not mine, i was going to fix it for a friend of mine, he says if the engines damaged hes going to scrap it...... so well see
post #4 of 11 Old 09-30-2008, 09:03 AM
My Ride: Starion
if he's going to scrap the car, grab it or get it to someone that wants it. you can always pull the head, get some valves and use for hybrid conversion.
if he's determined to junk the car, cut off the cat ($80-$100 value) get the head and then let it go.
pobort is offline
post #5 of 11 Old 09-30-2008, 10:05 AM Thread Starter
TD Hardcore User!
My Ride: 87 GLHS
Engine: 2.2l turbo
well hes a friend of my mother in laws so if he wants to junk it and i have the top end torn apart im going to charge him for my time to take the top end off and see if he just wants to give me the car instead and ill put a head on it and maybe throw that garrett t2 i got laying around here on it :)
post #6 of 11 Old 10-25-2008, 10:08 AM
Garrett Booster
My Ride: 77 Celica Liftback
Engine: 2.4L Dodge 420a
wrong, the NA, stock 2.4L is Non-interference(or they are supposed to be anyway) the DOHC 2.0L neon engines are interference though....however this is all just hearsay, I've never had a timing belt break on any of my 2.4s, I always replace them well within time
wicked93gs is offline
post #7 of 11 Old 10-25-2008, 02:22 PM
My Ride: Starion
wrong? where are you getting your information? if you are right, why do i have a 2.4 with a broken timing belt and 8 bent valves? hmmmm. chrysler fsm says interference, shop-key says interference, on-demand says interference, gates belt catalog says interference.
so your are for sure that i'm wrong?
pobort is offline
post #8 of 11 Old 10-25-2008, 02:52 PM
Garrett Booster
I just said it was hearsay, just from information other people had posted on other sites, which of course is why I included that disclaimer, I knew i could be wrong myself, makes more sense that its interference though...since the only difference between the 2.4 and 2.0 DOHC is the stroke(as far interference goes)I make it a practice to replace my timing belts at 75k miles or before, I also immediatlry replace the belt on any engine of mine with unknown mileage for the same reason(I know they are supposed to be a 100k belt, but I dont trust any belt to last that long)
post #9 of 11 Old 10-25-2008, 04:26 PM
Just A Guy
NAJ's Avatar
Straight from Dealer Connect.
2000 Status/Breeze/Cirrus 2.4L DOHC 16 Valve (SMPI)
ENGINE
DESCRIPTION
The 2.4 Liter (148 cu. in.) in-line four cylinder engine is a double over head camshaft with hydraulic lifters and four valve per cylinder design. The engine is free-wheeling; meaning it has provisions for piston-to-valve clearance. However valve-to-valve interference can occur, if camshaft are rotated independently.
The cylinders are numbered from front of the engine to the rear. The firing order is 1 - 3 - 4 - 2.
The engine identification number is located on the rear of the cylinder block Engine Identification
TIMING BELT
REMOVAL
Raise vehicle on hoist. Remove right front wheel.
Remove right inner splash shield.
Remove accessory drive belts. Refer to Group 7, Cooling System.
Remove crankshaft damper bolt, and remove damper. Refer to Removal and Installation procedure in this section.
Remove generator belt idler pulley.
Remove lower timing belt cover fasteners and remove cover Timing Belt Covers
Lower vehicle and remove upper timing belt cover fasteners and remove cover.
Remove right engine mount and support bracket. Refer to Removal and Installation procedure in this section
CAUTION: When aligning crankshaft and camshaft timing marks always rotate engine from crankshaft. Camshaft should not be rotated after timing belt is removed. Damage to valve components may occur. Always align timing marks before removing timing belt.
Before the removal of the timing belt, rotate crankshaft until the TDC mark on oil pump housing aligns with the TDC mark on crankshaft sprocket (trailing edge of sprocket tooth) Crankshaft and Camshaft Timing
NOTE: The crankshaft sprocket TDC mark is located on the trailing edge of the sprocket tooth. Failure to align trailing edge of sprocket tooth to TDC mark on oil pump housing will cause the camshaft timing marks to be misaligned
Install 6 mm Allen wrench into belt tensioner. Before rotating the tensioner, insert the long end of a 1/8" or 3 mm Allen wrench into the pin hole on the front of the tensioner Locking Timing Belt Tensioner While rotating the tensioner counterclockwise, push in lightly on the 1/8" or 3 mm Allen wrench, until it slides into the locking hole.
Remove timing belt
CAUTION: If timing belt was damaged due to incorrect tracking (alignment), the belt tensioner assembly must be replaced. Refer to Timing Belt Tensioner Assembly Removal and Installation procedure in this section.
INSTALLATION
Set crankshaft sprocket to TDC by aligning the sprocket with the arrow on the oil pump housing.
Set camshafts timing marks so that the exhaust camshaft sprocket is a 1/2 notch below the intake camshaft sprocket Camshaft Sprocket Alignment For Timing Belt Installation
CAUTION: Ensure that the arrows on both camshaft sprockets are facing up.
Install timing belt. Starting at the crankshaft, go around the water pump sprocket, idler pulley, camshaft sprockets and then around the tensioner Timing Belt - Installation
Move the exhaust camshaft sprocket counterclockwise Timing Belt - Installation to align marks and take up belt slack
NOTE: A new tensioner is held in the wound position by a pull pin.
Remove the pull pin or Allen wrench from the belt tensioner.
Once the timing belt has been installed and tensioner released, rotate the crankshaft two (2) complete revolutions. Verify that the TDC marks on crankshaft and timing marks on the camshafts are aligned as shown in Crankshaft and Camshaft Timing
Install right engine mount and support bracket. Refer to Removal and Installation procedure in this section.
Install upper timing belt cover bolts 4.5 Nm (40 in. lbs.)
Install the lower timing belt cover bolts 4.5 Nm (40 in. lbs.)
Install generator belt idler pulley and tighten bolt to 54 Nm (40 ft. lbs.)
Install crankshaft damper. Refer to procedure in this section.
Install accessory drive belts. Refer to Group 7, Cooling System.
Install right inner splash shield.
Install right front wheel.
Jan
1990 Daytona Shelby VNT
38 Years ASE Certified
post #10 of 11 Old 12-07-2008, 01:14 AM
My Ride: 1st Gen Neon 95'
Engine: 2.4L SRT Turbo Swap
the early 2.4 motors are non-interference motors (eg. 94, 95,)
TurboWhips is offline
post #11 of 11 Old 03-10-2009, 10:17 PM
My Ride: 86 glh turbo
Engine: t2 2.2l intercooled
leak down test. then u will know for sure.
dirtyglhturbo is offline
Human Verification
