Stratus 2.4 turbo is it possible - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
2.4l Turbo Discussion of the 2.4l turbo
post #1 of 7 Old 09-22-2010, 09:38 AM Thread Starter
My Ride: 97 lhs
i was thinking about buy a 2nd gen dodge stratus with a 2.4 engine in it and putting a turbo on it. i was wondering if it is possible and what would i need to do it and where would i go to get the items necessary to do this upgrade.
Thanks
jkalinay is offline
post #2 of 7 Old 09-22-2010, 10:11 AM
Una
Una's Avatar
My Ride: '84 Dodge Rampage
Engine: 2.5L
Re: Stratus 2.4 turbo is it possible
Welcome to TurboDodge.com. I've turbo'd a N/A 2.4, and a N/A 2.0.. The stock rods are good for about 250hp/250ft lbs torque. You might make it to 300, but you're living on borrowed time at that point. That said.. Things you'll need.. You'll need an AEM FIC piggyback, or a MegaSquirt. I recommend MegaSquirt because it's just all around better, has more features and is more user friendly. It's cheaper too.
The SRT4 turbo won't clear the firewall on a Stratus, so you'll need to pick up a manifold on eBay and use a normal turbocharger. Try not to go for some crazy large turbocharger, as your power goals will be pretty modest with a stock 2.4. There are 3 different (cast log) manifolds up on eBay.. One points the turbo straight up, one points it straight backwards, and one points it down at an angle. I imagine you'll need the down at an angle manifold. I'd avoid the stainless steel headers, you're not building a 10 second dragster, they don't have the greatest longevity for a daily driver.
I notice you mentioned 2nd gen Stratus. Be careful in your selection, some of them (the 2 door I believe) come with a horrible mitsubishi 2.4L motor. Nothin like smokin a ricer only to have that ricer point out your motor is pure rice. While some of the Strata come with the same 2.4L that was in the SRT4 Neon (right up and past the time that the SRT4 was discontinued), minus the reinforced SRT4 components.
You'll also need larger injectors, I'd guess about 750cc would do the trick. You can get the MegaSquirt, and the injectors at DIYAutotune.com. The manifolds are on eBay. I'd recommend running E85 to get around the fact that your N/A 2.4 has really high compression. E85 is 105 octane, so it's perfectly happy running 14+ lbs of boost on a 9.6:1 compression motor. You'll also need a wideband oxygen sensor to be able to tune your fuel curves. I recommend the Innovate LC1, they're cheap, and have just the right features for your needs.
Una is offline
post #3 of 7 Old 09-22-2010, 01:02 PM Thread Starter
My Ride: 97 lhs
ok thanks, but what kind of MegaSquirt kit will i have to get and what kind of turbo
jkalinay is offline
post #4 of 7 Old 09-22-2010, 01:32 PM
Una
Una's Avatar
Engine: 2.5L
Any MegaSquirt will do the job, MS1 if you're on a tight budget, MS2 if you want one that's easier to use. MS3 if you're on a large budget. They all support the 2.4 motors.
What turbo you use is up to you. If you can find a basic T3 turbo on eBay, that'd be the one to go for. Avoid things like "50 trim" or .63 ar or "T3/T4" because those will all be too big for your needs. .48ar would do well for you.. I'd recommend a basic TD turbo, if the bolt pattern weren't wrong.
You'll have to pick an intercooler as well, any intercooler should do. They start at like $50 on eBay..
Una is offline
post #5 of 7 Old 12-11-2014, 08:55 PM
My Ride: 06 Dodge Stratus
Hey Una what exhaust manifold did you use off ebay for your turbo if you dont mind me asking?
SWAGGOUTSTRATU is offline
post #6 of 7 Old 12-11-2014, 10:59 PM Thread Starter
My Ride: 97 lhs
I was looking into all the stuff I would need bc I didn't even have the car. And it seemed too unrealistic. All that work for something that might have not even worked. I ended up buying a 2011 Chrysler 200 it was 284hp and plenty of balls it also gets really good fuel Eco when I beat on it it never goes below 18mpg and when I baby it on the highway it gets up to 32mpg. I would really like to move up to a 300srt 8 but that's a little out of my price range. But I'm probably going to trade it in on a 300 with 3.6. I just really love the 300. My first car was a chrysler LHS, I just like big luxury cars. I like driving fast power cars but when I Have to driving it everyday it's not fun anymore. Sorry for the long massage I never came threw with a srt4 stratus, I settled for a middle of the road 200 with a 3.6.
jkalinay is offline
post #7 of 7 Old 12-12-2014, 05:55 AM
Ok, thanks for all your help
Tags
2.4 turbo , srt4 stratus , stratus upgrade
Human Verification
