2.4L swap, tranny question - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > 2.4l Turbo
2.4l Turbo Discussion of the 2.4l turbo
Old 02-26-2013, 12:04 PM   #1
Garrett Booster
BoostedSC is keeping the peace
Has anyone done a 2.4 swap using a TD auto trans?
BoostedSC is offline
Old 02-26-2013, 08:51 PM   #2
Re: 2.4L swap, tranny question
Una
Wise [arse] old TDer
Una's Avatar
My Ride: '84 Dodge Rampage
Engine: 2.5L
Feedback: (7)
Una is making this site a better placeUna is making this site a better placeUna is making this site a better placeUna is making this site a better place
That wouldn't make any sense. The 2.0/2.4 3 speed uses the exact same motor mount as the 2.2/2.5. So you'd use the one that bolts properly to the engine.
I've used an ATX from a '97 Neon with an '03 turbo 2.4 in my Omni. Worked quite well.
Una is offline
Old 02-27-2013, 06:47 AM   #3
---SITE GUIDES---
nvysion's Avatar
My Ride: Chrysler ES
Engine: 2.5L intercooled
Feedback: (14)
nvysion is ready to make a name for oneself
From what was told to me the trans are not the same, the TD trans is much stronger in some way(discs ?) than the NA Neon trans and the starter is not at the same place (rear in the TD cars)
nvysion is offline
Old 02-27-2013, 11:50 AM   #4
Una
Una's Avatar
Engine: 2.5L
Feedback: (7)
The starter location is the whole reason not to use the TD trans with the 2.0/2.4 swap. The clutch packs don't make it stronger, just make it hold the power better. You can swap them. The 2.0/2.4 trans got revised bearings that make them stronger/last longer. They also support a lockup torque converter, which is really nice with the high stall turbo torque converters.
Una is offline
Old Yesterday, 09:37 AM   #5
litemup is keeping the peace
Ive ran the TD 5 spds with a 2.4, and now am using a built auto out of a '95 neon. Was lazy this time around and just modified the L body 5 spd mount to work with the auto trans.
litemup is offline
Old Yesterday, 09:38 AM   #6
it was nice not taking an angle grinder to my block this time around.
litemup is offline
