Old 04-22-2005, 08:43 PM   #1
parts=hp, but which ones
ok guys, im budgting about 600-800 bux...so, what is the best bang for the buck...i was thinking about getting a stage 1, 3 in exhaust, boost controller and maybe a downpipe if it will fit in there...hoping that will be around and about 650 mark...feedback i need it!! thanks again!
if anyone has any parts for sale, pm me....thanks!
lil4drturbo is offline
Old 04-22-2005, 08:47 PM   #2
Stage 2, no toys
I'm holding out for a month or so and going with toys.
Keith Alto is offline
Old 04-22-2005, 09:40 PM   #3
My Ride: 04 SRT-4
Engine: 2.4L Turbo
Ive seen stage 2 for sale online somewhere for like $850 w/out toys....I would do that....I kind of wish I would have done that myself.
91RedSpiritRT is offline
Old 04-22-2005, 10:22 PM   #4
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
I would like to go the S2 route, only because I know there is no way i can afford S3.
contraption22 is offline
Old 04-23-2005, 12:26 AM   #5
Authorized TD Vendor
glhs727's Avatar
Feedback: (15)
$800 to spend?
some good upgrades include stage 2 with toys but way more than $800
3" exhaust, if short on money get it from the cat back, which is about 80% of your car, and then later you can add the DP. Remember, if you do the downpipe, you may as well change the O2 outlet. That is a tiny 2" outlet, replace with a 3" so you have a full 3" set-up. Boost controller set at 17 psi. Works good with s1 or s2.
You can pick up a used s1 kit with injectors for reasonable sum. If you have an 03, I have my old s1 kit for sale. That with a 3" exhaust and boost controller with be good. Get a BOV block off plate and put in a real bov. Get a better than stock wastegate actuater, or a BIG spring, the wastegate will open at 5 psi, so it needs help.
Other good things, bigger IC, bigger turbo or stage 3 kit.
Good motor mounts. Wheel hop is bad on our cars. Don't get a solid upper, use a decent insert or poly filled. And slicks or really sticky tires, cause traction is an issue. I also like the short throw shifter, and a coilover kit and swaybar kit too, Oh....right only $800 well you get the idea....
later,
Cindy
Your FWDperformance Team
281-288-4411 or 281-642-3878
glhs727 is offline
Old 04-23-2005, 04:50 PM   #6
well, i have the mopar bov and the sts....so those are out of the way.....umm poly insersts is a good idea....only about 20ish...stage 2...dont know if i want to do that or go stage 1 with the full 3 incher...ohh yeah about the stage 1 for sale....ur is for a 03, but wont they work with the 04's? thanks again!
Old 04-23-2005, 11:32 PM   #7
glhs727's Avatar
Feedback: (15)
Yes, the s1 one will work with both, you just won't need the injectors for the 04. I sell mine for $250 w/o injectors. you will have to get it programmed at you local dealer for you vin # though.
Thanks,
Cindy
glhs727 is offline
Old 04-23-2005, 11:46 PM   #8
pm sent cindy!
Ringtones | Gas Suppliers | Personal Car Finance | Online Advertising | Free Ringtones
Page generated in 0.39014 seconds with 13 queries
