Old 05-04-2005, 08:46 AM   #16
dodgeomniglh:What did you break?
We bent rods every time. Keep in mind I use bigger than average turbo's on all my projects so that it can make more power with less of a hit on the bottom end. The turbo used was a t3/t4 hybrid 54 trim with a stage 3 exhaust wheel in a .63 housing.
89acclaim Yes the SRT4 rods and pistons will go in the older 2.4 block.
You might want to check out these pages.
http://www.bstockum.com/
http://home.bellsouth.net/p/s/commu...oupid=45129&ck=
http://www.lowtech.net/nstenz/build/
Have fun.
HAHAHA! The second URL is my OLD bellsouth site! I didn't that was still up... Go to WWW.TRAILERBALLRACING.com tis the latest site albeit the last time I updated it was @ two years ago.
Andre' Parker Turbodave, you have the highest number I have seen. I have seen almost every turbo 1st gen around my area die after trying to hit 220 or so at the wheels. I think 250 at the crank is about as far as you can go with any chance of any longevity. .
If they use a small turbo and make full boost below 3000 yeah they will die quick! If a small turbo has to be used have a bling bling boost controller that does RPM based boost control and limit it that way. Keep the max boost onset above the torque peak and it will live a long life. Cylinder pressure is the killer here.
turbodave/neon is offline
Old 05-04-2005, 01:42 PM   #17
Turbodave, i was looking on your site and i didn't see any mention of what trans you are using? Stock neon, Stratus, or top secret? I assume its the stock trans if you're using the stock axles.
Very nice car, btw. I hope to have one of my own soon.
dodgeomniglh is offline
Old 05-04-2005, 05:40 PM   #18
THANKS!
I am in the process of buying it back and rebuilding it. This time it will make real powa!
BTW it was a stock trans with a quaiffe and DSS axles.
Direct TV | Get mysqli last insert id | Mortgages | Bad Credit Mortgages | Web Games
Page generated in 0.38024 seconds with 13 queries
