Old 12-13-2005, 05:08 PM   #1
Alternate parts thread-OEM to aftermarket-post findings!
Ok guys, post parts you have found that fit TIII's that are from other cars, and aftermarket suppliers.
I will also keep it clean and delete postings that are irrillevent so no pages of crap to find numbers.
Old 12-13-2005, 05:10 PM   #2
The front seal is CR part #11111,
The cam seals are #14707
Rick added:
Federal-Mogul (National Seals)
Cam Seals = 223801 - part number is for one seal
Rear Main Seal = 710056
Intermediate Shaft Seal = 3655
Front Crank Seal = 3638
National also sells a Teflon rear main seal for the 2.2/2.5's. Personally I think they suck as they have no spring to keep tension on the seal. Your results may vary.
Last edited by Rick; 07-07-2008 at 10:48 AM. Reason: I added Federal-Mogul part numbers which are more common than CR or Chicago Rawhide as first posted
Old 12-13-2005, 07:34 PM   #3
My Ride: Spirit R/T
Engine: TIII
Dodge Viper oil cap, I took the gasket off the viper oil cap and put it on my stocker.
Tudds is offline
Old 12-14-2005, 09:07 AM   #4
TI/TII/TBI commonblock can be substituted for a trashed TIII block. Grind in the water pump passage area for clearance for the water deflector. Place a core plug in the distributor hole. Crankcase breather can be added by drilling a hole in the distributor core plug and installing breather there (before installing plug!). TBI block will also need to be drilled for turbo oil return on the rear of block.
Substitute thermostat gasket: Use a thermostat gasket from a '94 Dodge 5.2 V8.
Scottmon is offline
Old 12-16-2005, 06:01 PM   #5
head studs... Acura VTEC B18CI, 11mm. arp part number 208-4303 they are the 11mm ones for the 1.8 vtec. I had to go this route when building my engine because our vendors were out of stock, but everyone and their mothers sell honda parts.
-Jerry
sandmcrew2 is offline
Old 12-20-2005, 12:58 PM   #6
hoses and belts
My Ride: 92 Daytona iroc R/T
Engine: 2.2 to be 2.0 DOHCT3
i have part numbers through goodyear for:
radiator hose upper 61782 idler pulley 49038
lower 61341 timing belt 40206
heater hose htr to wp 63073 surp belt 4060785
htr to eng63275
Daytonadrew101 is offline
Old 03-27-2006, 01:34 PM   #7
Crankshaft Sensor PC149 Standard Brand (Chrysler part reboxed)
Crankshaft Sensor SU356 Wells brand (Chrysler part reboxed)
Camshaft Sensor CSS708 Napa brand (Chrysler part reboxed)
I just purchased one for me 3/17/06 and they said they had one more shown on their computer in the country Good Luck! I was tempeted to purchase it but I didn't want to be greedy I tried everyone else I could think of on the internet and came up empty handed except from Napa. As many of you know Chrysler has NS1 this part.
Timing Belt Gates T206
Camshaft Seals 223801 National brand
blhlfam is offline
Old 07-05-2006, 04:11 PM   #8
DaPepster!'s Avatar
My Ride: '91 Spirit R/T x2
Engine: 2.2L DOHC T3
High pressure Power Steering Hose - Powercraft 91703
Also bumped the high pressure steering hose topic in the TIII section.
DaPepster! is offline
Old 07-06-2006, 02:26 AM   #9
belt and hoses
cdd
My Ride: PT Cruiser
Engine: 2.4 DOHC
T3 w/o ac belt - Dayco 5060670
Hoses from Carquest
lower radiator 21639
water box to heater 18948
water pump to heater 18075
Unable to get upper radiator hose through Carquest (used Goodyear 61782)
note: Goodyear hoses looked thicker than Carquest
cdd is offline
Old 08-20-2006, 11:08 PM   #10
My Ride: 2005 Dodge SRT-4 ACR
Engine: 2.4L DOHC Turbo
Part /Brand /Aftermarket Part # /OEM Equivilent
Crankshaft Position Sensor /Borg Warner /CSS72
Camshaft Position Sensor /Borg Warner /CSS74
Oxygen Sensor /Bosch /13275
Fuel Injector /GP Sorenson /800-1047N /5277895
Coolant Level Sensor /GP Sorenson /FLS82
Water Temp. Switch (guage) /GP Sorenson /TSU113
EGR Valve (w/ transducer) /Niehoff /FE-3039 /4287781
Ambient Air Temp Sensor /GP Sorenson /TSU180
Air Pump Check Valve /Niehoff /FE-476 /4300376; 4041966
Air Charge Temp Sensor /Niehoff /TS81261
Throttle Position Sensor /Niehoff /FE1088 /5234901
Knock (Detonation) Sensor /GP Sorenson /KS1 /5213629
M.A.P. Sensor /Niehoff /FE-1626 /4686181; 5234971
M.A.P. Sensor /Niehoff /FE-1627 /5234327
Idle Air Control Valve /Niehoff /21811 /4612159; 4612673; 5277839
Coolant Temp sensor (2 pin) /Niehoff /TS82231
Oil Pressure Switch (guage) /GP Sorenson /OPS121
Water Pump (new) -GMB/ Prestone -120-3060 -4626682/ O.E. Casting #4483455
Water Outlet Gasket /Fel-Pro /35286
Thermostat /Prestone /338-192
Bypass Hose (heater to water pump)/ Goodyear /4337
Upper Radiator Hose /Goodyear/ 61782
Lower Radiator Hose /Goodyear /61341
Idler Pulley /Goodyear /49013
Idler Pulley /Goodyear /49038
Serpentine Belt /Goodyear /4060785 or 785K6
Radiatort Fan Assembly /Dorman /620-008
Oil Filler Cap /Stant /10066
Right Side Motor Mount /Anchor /2616
Front Motor Mount/ /Anchor /2615
Manual Transmission Mount /Anchor /2618
P.C.V. Valve /Fram /FV163
Crankcase Breather Filter /Fram /BA6662
Carbon Canister Filter (4.5in Dia.) /GP Sorenson /779-1000
I gnition Coil /Wells /C939
Spark Plug /Champion /RN12YC
Spark Plug Wire Set (red) /Accel /5109R
rich tideswell is offline
Old 09-02-2006, 05:47 PM   #11
AWD alive
good stuff ....TYVM
mech1nxh is offline
Old 09-02-2006, 08:20 PM   #12
DaPepster!'s Avatar
TIII engines were never equipped with an EGR system.
Old 09-04-2006, 01:01 PM   #13
yea, i'm finding that when i'm looking some of this stuff up its listing parts for an 8v...bear with me, i'm slowly getting it ironed out, hence there are 2 listings for the map sensor.....
Old 09-10-2006, 10:48 PM   #14
are you sure about the right side motor mount?? Cause I NEED one and all the TD websights want like $80 for one and according to your part and brand #s, I found one for $13. Just to make sure, this is the one on top on the passengers side. Thanx for that AWSOME list!
speed127 is offline
Old 09-10-2006, 11:03 PM   #15
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Wrong plugs also, air pump ck valve???, coolant level sensor???
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Web Advertising | Friendster Comments | Myspace Layouts | Per Insurance | Proxy
Page generated in 1.73245 seconds with 13 queries
