Old 10-21-2007, 07:00 PM   #1
91 ECU in 92 R/T
Hybrid Booster
LowSL2's Avatar
My Ride: Red 92 Spirit R/T
Engine: 2.2L T-III
I got a 91 ECU from 89daytonashelby (thanks!) so I re-wired the 92 ECU connector according to the instructions in this thread:
91' R/T Trimcal in 92' IROC R/T
Once I got the engine started (took 10 minutes to get it to fire which could be because it sat for almost a month), I got a code 41.
The FSM says: Alternator Field not switching properly. An open or shorted condition detected in the alternator field control circuit.
I moved the wire from pin 57 to pin 8 like the instructions say. I even checked for continuity between pin 57 and the dark green/orange wire on the ASD relay which checked out ok. I dont have a 91 FSM yet to compare schematics so I'm relying solely on the schematics posted in the thread posted above.
The alternator is charging fine. I get 13.8V charge system goal and 13.7V at the battery. I just get this code 41. I have a powertrain diagnostics manual but it's for a 93. So it's no help.
Any ideas?
LowSL2 is offline
Old 10-21-2007, 10:02 PM   #2
Re: 91 ECU in 92 R/T
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
I got code 41 when I put a 91 SBEC in my 93 to test it. Everything seemed fine but it just threw that code
BTW: I have both 91 and 92 FSM sets about 5 feet from where I am typing,maybe I will look at them here in a few.
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 10-22-2007, 01:08 AM   #3
Hybrid Booster
LowSL2's Avatar
Engine: 2.2L T-III
When you tried it, did you move pin 57 to pin 8? If you do look at the FSMs, can you trace pin 8 on the 91 ECU connector? I need to know if it goes to the ASD relay or not.
If I got a 91 wiring harness do you think this would help things?
LowSL2 is offline
Old 10-28-2007, 06:54 PM   #4
Hybrid Booster
LowSL2's Avatar
Engine: 2.2L T-III
Ever since I put this 91 ECU in, the car drives weird at constant speeds. It's hard to explain. It's almost like a slight shudder or bucking feeling. It's really slight. Enough to piss me off and to make my passengers sick. At wide open it hauls balls though.
LowSL2 is offline
Image Hosting | Cheap Car Insurance | Money | Hot Music Video | Credit Cards UK
Page generated in 0.46577 seconds with 13 queries
