10-21-2007, 09:45 PM
Re: Cam sensor for a 91 RT
Super Moderator
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
If you have tried that many cam sensors, I bet its the wiring as well.
Cory Hedin
10-21-2007, 09:53 PM
My Ride: TIII R/T
Engine: 2.2L TURBO III
+1 on it not being the cam sensor
10-21-2007, 10:50 PM
My Ride: '91 Spirit R/T x2
Engine: 2.2L DOHC T3
Was there any work being done on this car before all this happened? I'm betting it's possibly the wiring, but definitely NOT the sensor itself...
10-21-2007, 10:57 PM
SHELBY 16V !!!
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Ya,I would check continuity from the cam sensor plug to the SBEC....
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
10-22-2007, 10:18 PM
My Ride: TIII R/T
honestly, we dont replace unless its not working at all. normally when it goes bad, the car doest start as the sensor doesnt show a signal. your problem i think isnt a sensor. thats why i keep good used spares and buy known good used ones.
10-23-2007, 06:36 AM
Another 16v is running!
My Ride: SPiRiT & IROC R/T's
Engine: 2.2L TIII
David, you are welcome to borrow the sensor off my Spirit. The one I loaned you ran fine on the IROC. OR bring the "lot" over and we'll run them on my Spirit.
Maybe the mouse that got a hold of your Daytona got a hold of the R/T?
10-23-2007, 01:52 PM
My Ride: 91 Spirit R/T
The cam sensor has 3 wires going to it, 2 of the wires are spliced and shared with the crank sensor and the third wire is the signal wire. With the key on sensor unplugged the orange wire should have approx 8 volts, black with blue strip is a ground, and tan with yellow strip is 5 volts. With the sensor plugged in and engine running there still should be 8 volts on the orange, ground on the BK/BL, and the TN/YL pulses 0V to 5V square wave and this can only be check properly with a scope. A couple of test you could do are measure voltage with a volt meter on the orange wire and black/blue wire while running to make sure they don't change while running by a poor connection, bad sensor, ect. You can also measure voltage on the signal wire with it connected turning the engine over by hand and see if the voltage switches from 0 to 5 volts.
