Old 10-23-2007, 09:00 PM   #1
what is everyone running?
My Ride: 2004 DAKOTA 4.7
Engine: 4.7
To the guys that have minor or major mods to your TIII's, what combination in your opinion seems to work the best for max power without sacrificing any driveability?
In other words, what setup works best for you?
Many thanks
Lee
Ft Myers, FL
1992 IROC R/T
swflpeep is offline
Old 10-24-2007, 12:17 AM   #2
Re: what is everyone running?
My Ride: 91 Spirit R/T
Engine: TIII
The setup I ran a couple years ago worked great. Ported head & manifolds. Lonewolf stage 1 cams. 3 bar/+40 cal from FWDP. Hybrid turbo. spearco FMIC. 3" exhaust. 322 whp @22 psi with 180k on the bottom end. The car has been down for 2 years, should be a bit better with a freshened bottom end.
86Shelby is offline
Old 10-24-2007, 01:12 AM   #3
My Ride: 600ES Turbo 'vert
Engine: Turbo II / A568
I've been extremely happy with my T3 with the following mods:
+0.020" Forged Venolia Pistons
Lightly ported head
50 trim T04E/T3 0.63A/R hybrid with Stage III turbine wheel
3" V-band Swing Valve and Downpipe w/ Full 3" mandrel bent exhaust
Modified SRT4 FMIC
+20% Injectors w/ AFPR
Alcohol Injection
17 psi boost
The only thing i found with this larger turbo is spoolup time is a bit later (3500 for full boost) so you cant just tip into the throttle at a cruise and expect to have full power immediately. The top end more than makes up for this small sacrifice...A quick downshift and away you go. The car made 320 whp this past July on this setup.
CNH320 is offline
Old 10-24-2007, 07:03 PM   #4
My Ride: 92 Iroc R/T Red
Engine: TIII
Fort Myers huh not too far from here. I have a stock engine with a 3" exhaust from FWDperformance and stole the 15 psi 2bar cal and +20 injectors out of my other R/T. I just added an AFPR because the cal was a bit rich but haven't fine tuned it yet I waiting on a new walbro fuel pump. Runs good but doesn't like all the hot air down here. once it finally cools down it will like that much better.
Tim
charger R/T is offline
Old 10-24-2007, 07:49 PM   #5
Blue Iroc R/T's Avatar
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
To start off with, the best set-up for a TIII is: one with a Head that isn't cracked!
I am happy with my setup now that I have a head that has been weld repaired. I am running basically Stock with exception of Titanium valve spring retainers and ORIGINAL exhaust. Not the fastest R/T out there, but it runs good for stock, and for this car, that is probably where I will try to keep it.
Ralph
www.pbase.com/rmscott
Blue Iroc R/T is offline
Old 10-24-2007, 08:57 PM   #6
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
135K stock Bottom end TIII
58MM TB, Ported Intake to match and Ported Exhaust manifold.
FMIC 25 x 10 x 2.5
54 Trim Stage 2 T3/T4 turbonetics turbo with full 3 in mandrel bent exhaust turbo back
21 Psi
Stage 3 Cal from FWD performance
255 Walbro Pump
Accufab adj Fuel Pressure Reg
Devils own progressive alcohol inj M7 nozzle 75%meth alcohol/25%water mix
xtrempickup is offline
Mortgage Calculator | Mortgage Calculator | Personal Loans | Personal Loan | Loans
Page generated in 0.40115 seconds with 13 queries
