Old 11-22-2007, 11:55 AM   #1
motor lift points
Pretty much as the title states, I have the motor almost ready to drop into the car again. I have the block back together and the head with the turbo and exhaust manifold attached. I would like to put the whole thing in together. What's the best place to lift the motor from?
Thanks,
Bryan
doomedjest is offline
Old 11-22-2007, 12:22 PM   #2
Re: motor lift points
My Ride: 91 Spirit R/T
Engine: TIII
I lifted from the front motor mount, a bellhousing bolt and a bolt hole on the head. Sorry I don't have a better picture.
86Shelby is offline
Old 11-22-2007, 12:26 PM   #3
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
i dont have any pictures, but i did with mine all together using the ac bracket and a bolt and the other end of the chain around the turbo. it actually lifted it on the perfect again to get the tranny and motor back into my car which has the abs box on the driver side
xtrempickup is offline
Old 11-22-2007, 01:53 PM   #4
Post Re: motor lift points
DaPepster!'s Avatar
My Ride: '91 Spirit R/T x2
Engine: 2.2L DOHC T3
When I yanked my motor/trans out of my Spirit I parted out a couple months back, I just wrapped one side of the chain around the pass side motor mount and unbolted it from the body, and the other side of the chain I bolted to the top two tranny bolts.
I wouldn't recommend mounting to the cylinder head's ground bolt; too much stress on that one little aluminum part, IMHO.
DaPepster! is offline
Old 11-22-2007, 05:23 PM   #5
I like the idea of lifting from the bell housing, but the trans is still in the car, so I'm a little unsure of what to use on the driver's side. Considering the cost invovled in rebuilding the head I would rather not use it as a lift point either
Bryan
Old 11-22-2007, 06:02 PM   #6
I yanked a 2.2 TBI with the A413 tranny attached from an 89 Shadow. I used the threaded hole in the back (tranny side) of the head, where a ground strap is connected on some applications, with a 2" bolt and a healthy washer. I also used the front (front of the engine if it were in a rear whell drive vehicle) motor mount bracket. If you remove the through bolt for the motor mount (passenger side) and then jack up the engine on that side enough to drop the chhain into the bracket and replace the through bolt so the chain is locked in place. I also used a rachet strap wrapped around the intake and exhaust manifolds and then connected to the hook of the hoist to stabilize the engine from rotating. All went well for me.
Be safe and be blessed!
Sasky
BareFoot Soul - A Christian Rock Band
Christian Rock
Sasky is offline
Old 11-22-2007, 06:27 PM   #7
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
Whenever I have pulled a TIII motor(and trans together always) I would use that 10mm bolt hole on the driver's side front corner of the head and I made a "engine lift bracket" that I bolt to the three 8mm bolt holes that are in a triagular pattern and the passenger side rear of the head. Never had a problem doing it this way and I have done it like this for both installing and removing motors and have done at least 10 this way.
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 12-02-2007, 05:14 PM   #8
My Ride: '85 LeBaron
Images: 7
id use the alt. bracket and the bolt on the left side of the head as said above
boosted_baron is offline
Tutorials | Credit Card Consolidation | Loans | Credit Card | Gas Suppliers
Page generated in 0.34370 seconds with 13 queries
