01-16-2008, 01:09 PM
Re: weaping head
SHELBY 16V !!!
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Well,if you dont want to deck the block I would just get it as flat as you can with a block and use a Mopar TIII HG with copper spray on that. I would get the head machined at least tho....
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
01-16-2008, 08:08 PM
Re: weaping head
My Ride: TIII R/T
Engine: 2.2L TURBO III
+1 on Cometic headgasket and copper gasket sealer
01-17-2008, 03:41 PM
Re: weaping head
Authorized TD Vendor
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
VERY IMPORTANT! When using the COmetic the head has to be surfaced to a RA25 or smoother. I would just scotch bright the block to make sure its clean and dry if your not going to deck it. Dont use anything grittier than 400 if you block it. ARP studs are a good addition.
Wallace
91 Spirit R/T
11.686@120.89 mph
01-17-2008, 05:11 PM
Re: weaping head
Hybrid Booster
My Ride: Red 92 Spirit R/T
Engine: 2.2L T-III
So if the block is nice and flat I could get away with doing a usual block sanding to smooth it out? Like when you wet sand when polishing something? I've done this with Saturn engines but those are a different animal than TD's.
How about the head?
(I can see it now, someone is going to wet sand their block and then use an orbital polisher to get a mirror shine. Haha.)
01-17-2008, 05:43 PM
Re: weaping head
Engine: 2.2 TIII
The smoother the better. Id use a marker and color the top of the block and use a sanding block and lightly sand it to find any low spots, if you find one Id use a straight edge and feeler gauge and check it. Then switch to like a 800 and block it some more. Just like wet sanding.
As to the head take it to a shop and have it surfaced to RA25 or smoother. Its cheap enough to have done and you know its flat.
Wallace
91 Spirit R/T
11.686@120.89 mph
01-17-2008, 09:17 PM
Re: weaping head
SHELBY 16V !!!
Engine: 16V TIII
Actually if you go with the Cometic you dont have to plug that hole if you dont want to. That was a good fix when using a stock composite gasket that over time cold break down and start leaking there. A Cometic,being a steel gasket,wont have that problem.
Andy
If I were you I would really think about getting the block decked if you go with a Cometic. You will have alot better luck getting it to seal up. I have Cometics on three of my TIIIs and only two of them have been decked and milled and niether of those leak at all and the one that only had the head milled actually dont seal up 100%. What mods and how much boost do you plan on running?
~Jackson~
TIII GURU
91 Spirit R/T
