04-11-2008, 01:15 PM
#26
Re: The Making of "Evil Spirit"
Administrator
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Well, I know it will choke it off a little, but I plan on porting the hell out of it. So that should help. Plus, I am finding lots of dsm guys that got into the 500+whp range with that housing. So I am hoping it will do ok. Wallce did trap 118 on this thing as well. And I believe that was on a unported head and manifolds. Not sure if he had his cams in or not. The turbo should be a street monster. He was seening full boost by 3700 rpm and was just killing the slicks in 1-2nd gear.
Here is my supporting mod list.
-Aroura 8.5mm wire
-Manual boost controller (for now, Greddy ProfecB coming soon)
-2.5" mandrel bent exhaust
-3" Downpipe dump with electronic dump valve
-Magnaflow muffler and high flow cat
-Turbo XS RFL BOV
-strut tower bar
-AutoMeter boost gauge
-PolyBushings.com poly motor mounts
-Solid bobble strut
-McLeod Revloc Clutch and dual diaphram Pressure plate
-rebuilt A568 trans. from FWD Performance
-B&M short throw shifter
**Engine Build**
-Rebuilt shortblock w/ Venolia forged pistons, polished forged crank, shot peened forged rods with re-drilled tops, sealed power rings, clevite main and rod bearings, ARP hardware, melling high volume oil pump, Ishihara-jonhson windage tray and oil pan baffle, Balance shafts removed.
-ARP headstuds
-Cometic .074" mls headgasket
-LoneWolf performance head with stage one port/polish, radius cut and back-cut valve grind and upgradedGEN3 FWD performance lifters.(Intake=280cfm@.350" Exhaust=224cfm@.350")
-LoneWolf performance stage one cams
-LoneWolf performance ported intake manifold
-LoneWolf Performance ported and coated exhaust manifold drilled and tapped for EGT probe.
-Spearco. 1010 CFM front mount intercooler with mandrel bent 2.5" pipeing
-Fidanza light weight flywheel
-Oil cooler
-FWD Performance Cutsom 3 bar computer calibraton and 3 bar map sensor
-58mm Throttle body
-Accufab AFPR
-58lb/hr injectors
-High flow billet fuel rail
-all -an fuel lines
-Walbro 255 fuel pump
-Holset HX-40pro Turbo
-TurboConcepts 38mm external wastegate (with 1 bar spring)
-Custom 3" mandrel bent Downpipe with external wastegate dump
-DevilsOwn Progressive Methanol injection kit (with m7 jet for the moment)
-Zeitronix wideband o2 meter with wideband o2, egt, boost, rpm, and tps monitoring and datalogging.
-OTC 2000 scanner/datalogger
I am hoping I will be happy with it for the season. I know that bullseye just came out with a .70a/r housing for this thing, which would let me use the full 71lb/min flow ability the compressor has.
Jackson should be done with the downpipe in a few weeks and I willl let you know how it goes.
Cory Hedin
I have a running T3 car! Woot Stock head for now 12.3@111 low boost :evil:
-87' Daytona Shelby Z W/ T tops <----Now broken.... It never ends. :(
