06-11-2008, 08:05 AM
Had to share....
Super Moderator
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Cory Hedin
06-11-2008, 09:46 AM
Re: Had to share....
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Nice beads there!!!!! Is it finished? How are you going to mount your WG, dump it back into the exhaust like mine?
Keep us posted!
06-11-2008, 10:48 AM
My Ride: TIII R/T
Engine: 2.2L TURBO III
looks good
Super Moderator
Engine: 2.2 L T-3
I think it will be similar to that. But, I am dumping mine to atomosphere.  I like the nasty loud noise it makes. lol Its not quite done yet. Jackson is way busy, and I didnt give him some of the bolts he needed, so they are being ordered.
Cory Hedin
06-11-2008, 10:54 AM
Super Moderator
Engine: 2.2 L T-3
Thanks. But, Lotashelbys (jackson) deserves all the credit.
I cant WAIT to try it out though.
Cory Hedin
06-11-2008, 12:26 PM
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
Jackson will get it done a LOT quicker, IF you tell him you want it on, so you can drive your car to Carlisle.
Jackson does nice work!
Ralph
www.pbase.com/rmscott
06-11-2008, 01:46 PM
Hybrid Booster
My Ride: Red 92 Spirit R/T
Engine: 2.2L T-III
Ditto! Looks like Jackson does good work.
06-11-2008, 01:51 PM
My Ride: 91 R/T-66 pontiac
Engine: T3 2.2/ 4bbl 389BB
1/4: 13.940
well i know whos going to be doing mine next year!!!
06-11-2008, 02:12 PM
NORCAL
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
wow...very nice downpipe.
I'm getting the drift that "jackson" does custom welding for people??? or are you guys personal friends with him????
I'd really like some of his work also...
OH...whats that geting bolted to???
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
Reason: another question
06-11-2008, 04:07 PM
Thank you Jackson.
06-11-2008, 06:47 PM
Super Moderator
Engine: 2.2 L T-3
Jackson pretty much does it all. lol His plot of land in wisconsin is the RT mecca or somthing. lol Hes been tons of help with my car, and was nice enough to fit me in his busy schedual even though I drug my feet getting him the parts.
More updated pics, and install pics to follow in the next couple weeks.
Cory Hedin
06-11-2008, 06:48 PM
#12
Super Moderator
Engine: 2.2 L T-3
My IROC RT.
Cory Hedin
06-11-2008, 07:25 PM
#13
Super Moderator
Engine: 2.2 L T-3
lol I was totally planning on going, then I got laid off.  I really wanted to go. I hope to next year.
Cory Hedin
06-11-2008, 07:32 PM
#14
Authorized TD Vendor
Engine: 2.2 TIII
Cory, I talked to jackson today about your pipe, or um the down pipe.... You would be wise to stud the housing and use like a 10pt nut to add a bit of clearance on the weld.
Also, when installing the turboo, you need to put on the exhaust housing first then slide the compressor in and tighten the bolts a little at a time. At least that what I did on my R/T...Use anti-seize on every nut.
Wallace
91 Spirit R/T
11.686@120.89 mph
06-11-2008, 07:35 PM
#15
Super Moderator
Engine: 2.2 L T-3
Thanks Wallace. Jackson is clearancing all the bolts and studs and stuff for me. Hes got my manifold, turbo, and downpipe. but I am sure I will be calling for some advice on fitting this bugger in.  Thanks for all your help wallace!
Cory Hedin
