Old 06-11-2008, 05:44 PM   #1
G-valve
My Ride: 92Daytonas/72Charger
Engine: 2.2 T3, 2.5 and 440
Ok, im sorry but i have a beginer question.
I made a g-valve and now i was going to install it.
But i want to be sure, do i completly by-pass the wastegate solenoid by pluging
the vaccum line direct from intake vaccum source to the wastegate actuator with the g-valve in between ??
With this setup the wastegate solenoid isnt use anymore at all, thats ok??
kriss440 is offline
Old 06-11-2008, 05:52 PM   #2
Re: G-valve
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
yes, you have the right.
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
86trbolancer is offline
Old 06-11-2008, 05:56 PM   #3
Re: G-valve
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
Correct!~
Old 06-11-2008, 06:53 PM   #4
Re: G-valve
AWESOME!
ill let you know about the result
still have to wait to get my crank sensor in the mail
kriss440 is offline
Old 06-11-2008, 07:10 PM   #5
Re: G-valve
Super Moderator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 119
Did you make sure to give it some kind of a bleed after the ball so that when the ball closes, the pressure trapping inbetween the WG and the ball in the controller wont let your wg shut. Make sense?
Cory Hedin
bansheenut420 is online now
Old 06-11-2008, 07:45 PM   #6
Re: G-valve
I followed Gus Mahon design to the letter, making a 0.020 bleed hole in the barb goint to the wg
kriss440 is offline
Old 06-11-2008, 09:31 PM   #7
Re: G-valve
Super Moderator
Engine: 2.2 L T-3
Images: 119
Cool, you will have no problem then. Keep us updated on how it works for ya.
Cory Hedin
Old 06-21-2008, 07:47 PM   #8
Re: G-valve
Finaly, the sensor is replaced.
Got a damn hard time removing the old crank sensor, had to drill it till totaly anihilated to get the remains out.
I also instaled my g-valve... ITS AWESOME! i cant beleive what a diference this 20$ home made thing can do, i love it!
kriss440 is offline
Old 06-21-2008, 07:59 PM   #9
Re: G-valve
Super Moderator
Engine: 2.2 L T-3
Images: 119
Yeah, if they get mushroomed at all inside the bell housing, they are no fun. Glad you got it all taken care of though.
The beauty of a turbododge! Have you uncorked the exhaust yet? The first few mods on these things have the most bang for buck that you can get out of then most cars.
Thanks for the update, and keep em coming.
Cory Hedin
Old 06-22-2008, 12:17 PM   #10
Re: G-valve
Hybrid Booster
My Ride: 1993 IROC R/T
Engine: 2.2L DOHC Turbo III
Ok, sorry for the question but:
What is a g-valve and how does it improve performance?
Thanks...
Moe
movaldes is offline
Old 06-22-2008, 12:31 PM   #11
Re: G-valve
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
Thanks...
Moe
basically an MBC made from McMaster-Carr parts found at Grainger Industrial Supply. g-valve is short for Grainger Valve
Screamin4banger is offline
Old 06-22-2008, 01:31 PM   #12
Re: G-valve
Engine: 2.2 turbo
Images: 2
MBC= Manual boost controller (just to clarify)
MBC also= More boost (thats what they are normally used for)
1986 Laser xt t1 5 speed sunroof-BUY IT AS WELL!
89 Lebaron GTC Convertible t1 auto- BUY IT PLEASE
Need a set of wagon wheels???- http://www.turbododge.com/forums/f7/...on-wheels.html
Old 06-22-2008, 06:49 PM   #13
Re: G-valve
Hybrid Booster
Thanks...
Moe
movaldes is offline
Old 06-22-2008, 10:08 PM   #14
Re: G-valve
Super Moderator
Engine: 2.2 L T-3
Images: 119
They cause quicker spool by not allowing the wastegate to open anything before the set boost. Makes a bit more power under the curve. Best 20 dollars you will spend on these cars.
Cory Hedin
