Old 06-12-2008, 07:34 PM   #1
temp sending unit for light and gauge?
My Ride: 93 IROC R/T
Putting the head on my TIII and noticed that the shop I had it to removed the temperature sending units from the front of the head and from the side under the therostat housing. The shop says they can't find them (plus their 10 hours away) so I am wondering if any 2.2 turbo units will work or if I have to order 93 TIII units from Chrysler? Any help would be great. BTW this is a very helpful site...
93IROC/RT is offline
Old 06-12-2008, 08:15 PM   #2
Re: temp sending unit for light and gauge?
I just checked Autozone online and they are only showing the sending unit for the gauge not the Coolant Temperature Sensor for the controller so I would say get Mopar, that way you know they are correct and calibrated for your car.
Old 06-12-2008, 08:34 PM   #3
Thanks but I guess what I'm wondering is if I can use the ones from my other 2.2's that I have laying around...88 shelby Z or what ever or are these specific to the TIII heads. Interchangeable?
Old 06-12-2008, 09:04 PM   #4
That I do not know. If you can get the Mopar part #'s I can tell you what years they fit.
Old 06-12-2008, 09:19 PM   #5
My Ride: 92 Iroc R/T Red
Engine: TIII
charger R/T is offline
Old 06-13-2008, 06:02 PM   #6
someone please help
Old 06-14-2008, 12:12 AM   #7
Turbo224's Avatar
My Ride: Daytona R/t
Engine: Turbo III
Images: 218
Originally Posted by 93IROC/RT View Post
someone please help
There is not a temp sensor on the front of the head. That is the knock sensor. The knock sensor is the same from all 2.2's. The sensor under the thermo housing is for the temp gauge (I believe) and is not used on any other 2.2. I guess its possible that it could be used on the 3.0's or the 3.3's, but I dont have any experience on those motors. Your best bet is the dealer. I cant imagine that little thing being more than $20.
~Tyler~Salt Lake City~Proud SDAC Memeber~
-92 Daytona R/T (PVP Pilot Car)
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
-70 Plymouth Cuda 440-6pk (in progress...sort of)
Check out my Homepage
"Half the people you know are below average"
Turbo224 is offline
Old 06-19-2008, 08:45 PM   #8
your totally right on that. It is a knock sensor. But I didn't know that 2.2's had a "knock" sensor. I hope you are right that I can use any 2.2 sensor, I just priced one and they are $98.00. So the only thing that resembles a knock sensor is around the 1 and 2 spark plug area on the front of the TII head. I always thought this was a temp sending unit. Is this the knock sensor your talking about?
Old 06-19-2008, 11:38 PM   #9
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
The temp gauge sensor that is on the BACK of the head right underneath the water box is the same for any 2.2 or 2.5 motor. I would get a good all brass one at the local auto-parts store. I would guess they will have them in stock. The coolant temp sensor(on the water box) is the same for any 2.2 or 2.5 as well and that same store should have that as well. Good luck
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 06-20-2008, 02:33 AM   #10
Turbo224's Avatar
Engine: Turbo III
Images: 218
The sensor on the front of the T2 head between the 1 and 2 plugs is the same sensor as the T3 sensor that screws into the side of the T3 head under the waterbox. The sensor on the side of the waterbox of the T2 head is the same sensor that goes into the waterbox of the T3 head. The knock sensor on the T2 cars bolts into the intake manifold right next to the fuel rail. The Knock sensor for the T3 bolts to the front of the head under the intake manifold. I hope that clears things up. In the first picture of the 8v head you can see both coolant temp sensors. Second picture you can see the knock sensor in the T3 head. Third picture you can see the knock sensor in the T2 two piece intake manifold. Hope that helps.
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
Turbo224 is offline
Old 06-20-2008, 09:56 AM   #11
everything has become crystal clear. Thanks for your patience, your a wealth of knowledge for sure. Now I can finally get back to putting this thing back together. BTW lottashelby's, this car came from Sturtevant area. Two years ago my wife and I flew to Milwaukee and drove it back to the east coast. It is in perfect shape and only had 67000 (now 72000) on it when we got it from the original owner. I know this sounds funny but an older lady (60ish) owned the car since new and she stored it every winter. It was quite a find but I gotta say if I'd known it had a cracked head I would have walked home and left it there seeing as nobody around here does head welding. The closest place is Montreal Canada and I think it was their first tim working on a TIII head. They warranteed it for a year so I'm hoping it will be ok. Thanks again for all the help.
Online Loans | Loans | Ringtones | Loans | Debt Consolidation
Page generated in 0.41942 seconds with 14 queries
