Old 06-30-2008, 05:36 PM   #16
Re: Cooling issues
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
i have bone stock unmodified Tstat and stock 130K rad and i dont get above the 1st line almost anytime
xtrempickup is offline
Old 07-10-2008, 02:03 PM   #17
Re: Cooling issues
With the stock calibration is there a certain speed level over which the fan will not turn on? Around town the car heats up to the 2nd line and then the fan kicks on and it immediately cools down. However while on the highway it seems to reach the 2nd line and then continues to heat up as if the fan is not switching on. I still need to get that air dam but I was wondering if anyone knew the answer to this.
BoostedFool is offline
Old 07-12-2008, 07:49 PM   #18
Re: Cooling issues
My Ride: 91 R/T-66 pontiac
Engine: T3 2.2/ 4bbl 389BB
1/4: 13.940
i am not sure what the fan schedule is but i do know that with a fwdp cal you get better cooling.
glht_omni is offline
Old 07-12-2008, 09:57 PM   #19
Re: Cooling issues
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
It just tells the fan when to come on and off. Its a computer program. You can also get a external temp switch to have the fan come on and off when you want it to. They are like 50-60 for a real good set up.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 07-13-2008, 02:09 PM   #20
Re: Cooling issues
My Ride: 1991 Spirit R/T
Engine: 2.2 TIII
My Spirit was missing the air dam. Here are pics of the air dam I got when I used the part number from the TSB. This is a dealer part.
Powerlinefixer is offline
Old 07-13-2008, 03:38 PM   #21
Re: Cooling issues
My Ride: 85 GLHT, 87 ShelbyZ
I like this on my Td's. 100_0592
S10 Airdam pics
Hugely important. I have a shelbyZ with a cummins, fog lights in the air vents, a/c, and a T2 rad. No issues with cooling even with a 195 degree t-stat. Also helps with downforce. Make sure the air can't get around things. Use whatever you can to force the air through all the heat exchangers. I have the underside of the nose sealed off on the Z, and factory rubber pieces on the sides of the i/c and the bumper seals off the top. After that the air is forced through the a/c condesor and then through the T2 rad. The spot where the factory i/c sat is blocked off by a T304 SS sheet.
GLHNSLHT2 is offline
Old 07-14-2008, 11:05 AM   #22
Re: Cooling issues
What was the part number?
Old 07-14-2008, 03:40 PM   #23
Re: Cooling issues
Engine: 2.2 TIII
It's TSB 24-03-91, under Air Conditioning, "Poor Performance at Lower Speeds". It was issued in June of 1991. I don't have access to the Chrysler system anymore so you'll have to go to a dealer and have them look it up.
The bad news is that the part is most likely NS1 (cancelled), but somtimes a dealer locate will turn something up. If the part can't be had, a custom air dam may have to be made. A roll of lawn edging works well and doesn't look too bad.
Loans | Property in Spain | Loans | Buy Anything On eBay | Bob's Free Stuff Forum
Page generated in 0.60507 seconds with 14 queries
