Old 07-15-2008, 07:41 PM   #16
Re: Car running weird
My Ride: Silver spirit rt
Engine: 135
Images: 18
anyone
boostedhatch is offline
Old 07-16-2008, 08:29 AM   #17
Super Moderator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 119
Do you have a multi meter so you can check the resistance on the coil? That way you can tell if its a coil problem, or a coil driver problem. I couldnt find a way to test the coil drivers for correct voltage, but if you have a multi meter, I can give you the values for a good coil.
Cory Hedin
bansheenut420 is online now
Old 07-16-2008, 09:34 AM   #18
Engine: 135
Images: 18
How do I test it ?Not sure on a T3
Old 07-17-2008, 10:07 AM   #19
Engine: 135
Images: 18
Ok I just replaced the coil and cal runs great but code 43 keeps poping up but the car hits boost really good and idols good?WTF
Old 07-18-2008, 07:43 AM   #20
Super Moderator
Engine: 2.2 L T-3
Images: 119
Thats odd. I know my car had that same code, but then went away and I never had any other problem. Are you plug wires new? And whats the gap on your plugs?
Cory Hedin
Old 07-18-2008, 08:48 AM   #21
Engine: 135
Images: 18
I'll double check the gap.The spark plug wires look old I'll get a new set and try
Old 07-18-2008, 08:56 AM   #22
Super Moderator
Engine: 2.2 L T-3
Images: 119
Maybe you possibly have an arcing plug wire. I would definitely get some new ones. Keep us updated.
Cory Hedin
Old 07-18-2008, 05:49 PM   #23
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Put in new plugs and possibly wires. Or check to make sure the wire clicks onto the plug. Ive had the plug wire build heat/pressure int he boot and pop it off the plug terminal. It would run ok for normal driving but broke up under boost.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 07-18-2008, 07:52 PM   #24
Engine: 135
Images: 18
brand new plugs but wires my need changed.
Old 07-18-2008, 11:51 PM   #25
Super Moderator
Engine: 2.2 L T-3
Images: 119
What is the gap on the brand new plugs?
Cory Hedin
Old 07-19-2008, 07:40 PM   #26
Engine: 135
Images: 18
Well I thought I fixed it but doing the same thing.I need a wiring diagram of the car because when the car act funny running on 2 cylinders you shake the sbec and it fixes itselfThen when it's running good you hit a bump and it messes up again.Really starting make me mad and the plug that goes in to the computer isn't really snug fit,but all the pins are all the way in.They might be alittle opened up and need to be criped down alittle bit,so if anyones knows what I can do let me know asap.Another thing is the check engine light is on and it's code 43 but the car runs great just wont boost high when the check engine light is on?but runs good until I hit a bump
Old 07-20-2008, 05:01 AM   #27
Engine: 135
Images: 18
Heres a pic of computer amd I thought it was supposed to have 3 heat sinks
Old 07-27-2008, 12:35 PM   #28
Engine: 135
Images: 18
Well guys im trying a new computer and hopefully that fixes everything
Old 08-07-2008, 11:50 PM   #29
Engine: 135
Images: 18
Problem still there but I think I might have found the wire the DB/YL*
Old 08-12-2008, 10:18 PM   #30
Engine: 135
Images: 18
problem still there,I think it has to be a computer problem it has to be.I'm going crazy with this car and I can't find any 92 non alarm computers for my price range
WoW Gold | The eBay Song | Property for sale in Spain | 0% credit cards | Credit Cards
Page generated in 0.68235 seconds with 14 queries
