Old 07-09-2008, 08:26 PM   #1
Car running weird
My Ride: 86 glh omni
Engine: 135
Feedback: (-1)
Images: 18
Okay got my fuel problem fixed not moved on to a new problem.When I first start the car it runs on 2 cylinders( no spark coming from coil).But after it runs for a couple of min it start firing?.I was getting code 43 but now I'm not getting it anymore,so when the car starts firing on all clyinders when I go into boost it breaks up?.I got good idel and good vaccume like 15-18psi so I think my timing is good.What do you guys think
boostedhatch is offline
Old 07-09-2008, 08:41 PM   #2
Re: Car running weird
Level 1 Supporter
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (13)
sounds like a coil pack issue
xtrempickup is offline
Old 07-09-2008, 11:17 PM   #3
TD Extreme User!
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Check the coil pack connector. Sometimes they can get corrosion inside or the pins will get loose over time. I took mine apart, cleaned with wire brush, then slightly crimped them so they went over the pins in the coil a little tighter. The coil wires pass through other connectors on the way to the SBEC so it's best to check them as well. You can trace them fairly easily by pulling back the loom and following them.
iTurbo is offline
Old 07-09-2008, 11:36 PM   #4
Level 2 Supporter
My Ride: 89 Lebaron Conv.
Engine: 2.5 Turbo
Images: 2
Also wouldn't hurt to check the HEP!
Q
Old 07-09-2008, 11:55 PM   #5
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
TIII doesnt have a hep
rx2mazda is offline
Old 07-10-2008, 12:18 AM   #6
Level 2 Supporter
Engine: 2.5 Turbo
Images: 2
Oh shit my bad t3 section.
thats what you get for looking at the menu lmao my bad!
Old 07-11-2008, 02:36 PM   #7
Engine: 135
Feedback: (-1)
Images: 18
Okay now the car has a miss at idel and when you go to get in the boost it breaks up still no codes.I had to put a 3 wire o2 in the car and just colored match the wires could that be the problem?.Still have good vac and idel? and when I start the car up it runs on a couple of cylenders but it quickly fixes itself?What do you guys think I need help asap
Old 07-13-2008, 10:29 PM   #8
Engine: 135
Feedback: (-1)
Images: 18
anymore suggestion?Really want to feel the power of this car
Old 07-13-2008, 10:35 PM   #9
Level 2 Supporter
Engine: 2.5 Turbo
Images: 2
Wiggle your injector harness around a bit
I just did that to my t1 auto thats been missing like crazy and it seemed to fix the problem (I need a new harness BAD)
What tune up stuff have you done to the car?
(plugs, wires, filter etc.)
Old 07-13-2008, 11:38 PM   #10
Images: 35
TIII's are finicky creatures. What all have you fixed besides the cracked head?
ol"blue is offline
Old 07-14-2008, 12:15 AM   #11
Engine: 135
Feedback: (-1)
Images: 18
I didnt have a cracked head?When I got the car i had to replace the headgasket and cams but i have good idiel and good vac good fuel pressure now
Old 07-14-2008, 12:18 AM   #12
Engine: 135
Feedback: (-1)
Images: 18
Quick question?. I have a rail mounted fuel pressure gauge and at Idol it's at 49 with vac line on and when the vac line off it's at 59 is that about right or is my fuel pump getting ready to go out.I know it should be 55 with the vac line off but it's not and I pinched the return line and the pressure jumped up to 80 or more.When I prime the pump it only goes to 50 but when I did my other turbo car priming it twice it went to 80 quick.How long should the pressure stay in the lines after the car is shut off?.But I think the fpr is bad or something
Old 07-15-2008, 12:45 AM   #13
Engine: 135
Feedback: (-1)
Images: 18
OK So far I took it for a spin and when i stepped on it and it hesitated so I backed off and hitted again and it cam alive until about 4500 -RPM and it broke up again but man it felt good.I got home and checked the spark plugs wires and 1&3 have really good spark like spark shooting out like 2 inches.2&4 had some spark just enough to keep the car running but running rough but the spark was nowhere near as good as the other 2.I changed spark plug wires around and still no change so I went and bought a brand new coil.It will be here the 16th and I got it for 136.99 if someone needs a brand new one
Old 07-15-2008, 08:21 AM   #14
Administrator
bansheenut420's Avatar
My Ride: 92' RT/87' Shelby Z
Engine: 2.2L TIII/TII
Images: 119
Sounds to me like a coil driver issue inside the computer. Have you checked the voltage going to the input of coil? If your getting a real low reading then the coil is not going to have as much voltage to jump up. Do you have another computer to swap in by chance? Also another stupid question, whats the gap on your plugs?
Your fuel pressure is not off enough to be a huge culprit I dont think. The code you were getting, and now not is most likely what it has to do with. I will go find my FSM and see what the test procedure is or what voltages you should be getting on the primary side of the coil.
Cory Hedin
~Great Depression Racing~
12.3@111 low boost, stock head, hx40, meth, cams :evil:
-92' White IROC RT PVP Pilot Car <---- turbo dead... more on the way <evil>.
-87' Daytona Shelby Z W/ T tops (daily driver)<----ported head with other goodies (working out the bugs)
bansheenut420 is offline
Old 07-15-2008, 10:45 AM   #15
Engine: 135
Feedback: (-1)
Images: 18
I wish I had another computer I was getting code 43 but now im not
Page generated in 0.16702 seconds with 12 queries
