Old 07-29-2008, 02:34 AM   #1
Custom timing belt routing
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
This was an idea that me and a few others have been talking about for about 6 or 8 months now and I finally did something about it. That is idler between the intake cam and I-shaft run of the timing belt. That is the worst spot for belt deflection and with the idler there I think it will dampen ALOT of that and hopefully keep the I-shaft teeth and and belts alive much longer.
I pulled the motor out of a buddies beater Spirit R/T earlier today(thats why its ugly) and it was just sitting on the cherry picker and I wasnt tired yet,hmmm....
Well a half an hour later and it was all mocked up. It fits like it was supposed to come that way with only grinding a few things off the cast aluminum alt/AC bracket and drilling a hole for the idler pulley and counter-sinking the P/S bracket for a flat head socket cap screw to take place of where the idler used to be. Yes,it still uses the stock belt and you can still run the A/C
Heres a few picks of the mocked up proto-type. I will have to put a prettier version in the next car that goes together for some road testing.....
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 07-29-2008, 05:27 AM   #2
Re: Custom timing belt routing
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
That definitely looks like it will keep that belt under control better
Just a few Q's:
How many degrees would you guess the cams are advanced with stock gears?
Do you feel having the idler threaded into the aluminum a/c bracket will last indefinitely?
Looks good
Click Here: I need a 2DR L-Body REAR Bumper Mount
My Mopars:
85 Shelby Charger - Garnet Red/Silver <- 100% Rust-free - Beautiful one day
86 Shelby Charger - Black/Silver <- $150 Rust-bucket Beater
73 Charger SE - Gold/White top <- Rust-free - will be MS & TT eventually
91 Spirit R/T - White <- Sacrifice to the L-Body Gods
Screamin4banger is offline
Old 07-29-2008, 08:37 AM   #3
Super Moderator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 119
you sir, are THE man.
That is all....
Cory Hedin
bansheenut420 is offline
Old 07-29-2008, 03:51 PM   #4
Hybrid Booster
My Ride: 1993 IROC R/T
Engine: 2.2L DOHC Turbo III
Sign me up...
Would this change the tension setting on the belt?
movaldes is offline
Old 07-29-2008, 08:28 PM   #5
Millerman340's Avatar
My Ride: 91 spirit r/t
Engine: TIII
Did it move over a tooth on the belt?
Millerman340 is offline
Old 07-29-2008, 10:29 PM   #6
Pat
My Ride: '88 Shadow ES 16v
Engine: 2.2 T-III
It will move the cam timing around a bit also...make sure you use adjustable cam gears and get those babies degreed in.
Pat is offline
Old 07-29-2008, 11:59 PM   #7
Blue Iroc R/T's Avatar
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
IMO, you would still time the cam in the same manner as per the FSM, it is just that the slack on the front of the belt would be taken out by the idler on the front. If the crank is at TDC and the Cams are Set to TDC, and the belt is tensioned correctly; as the belt moves, SO will the cams. I don't see that the idler on the front will have any affect on the cam timing.
Ralph
www.pbase.com/rmscott
Blue Iroc R/T is offline
Old 07-30-2008, 05:23 AM   #8
How about two smaller idlers. One in original spot and one in new spot?
eski is offline
Old 07-30-2008, 06:16 AM   #9
Pat
Engine: 2.2 T-III
The cams will move a few degrees because if the crank is at TDC and you pull some slack out of the belt on the front side of the cams, it will move the cam gears a few degrees. Typically the slack is pulled out of the back side.
Pat is offline
Old 07-30-2008, 10:22 AM   #10
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
+1
rx2mazda is offline
Old 07-30-2008, 11:57 AM   #11
SHELBY 16V !!!
Engine: 16V TIII
Feedback: (17)
Images: 1
I was thinking about that all day yesterday after what Millerman said and the worst it will do is advance both cam slightly and move the powerband down a few RPMs which wont hurt most TIIIs that arent heavily modified
~Jackson~
TIII GURU
91 Spirit R/T
Old 07-31-2008, 08:08 AM   #12
Engine: TIII
But what I was thinking was that if it was exactly the space of one tooth then it should not change, I've been hoping for this fix since my first belt break.
Old 07-31-2008, 08:55 AM   #13
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
It might move it, it might not. depends on if the added distance is equal to an even multiple of the tooth distance. It should be off no more than one tooth.
You could fix this by adjustable cam gears, or make the new pulley adjustable so that you can set the distance right so the top and bottom line up.
kermit is offline
Old 08-04-2008, 02:22 AM   #14
SHELBY 16V !!!
Engine: 16V TIII
Feedback: (17)
Images: 1
So,this has been bothering me all week to see if this works so I had to try it. Just got back from the first test run in my white Spirit with the idler on the other side
It seems to run a bit smoother and ALL of the harmonics or belt slap on the rev-down is gone. I guess they should of made them this way just like every other DOHC motor out there. Heres some pics.......
~Jackson~
TIII GURU
91 Spirit R/T
Old 11-22-2008, 02:25 AM   #15
professor chaos
dragbaron's Avatar
My Ride: '88 Lebaron GTC
Any problems with it since August? Were you able to do this conversion on your car with the motor in place? If you have decided that this works with no problems, could you give some instructions on what all tools and parts are needed(drill bit and tap size, power steering bracket bolt, etc)? The belt is off my car right now, so i thought i'd ask.
88 Lebaron GTC- T2'd/auto
91 Spirit R/T (finally got one! It runs and has all it's paint!)
72 Plymouth Duster-440 project (someday)
68 Plymouth Barracuda Formula S- 340/4spd (runs better than it looks!)
dragbaron is offline
