Old 07-02-2009, 07:52 PM   #1
oil pump help needed
My Ride: 86 shelby charger
i jus got done rebulding the motor in my daytona. i put in new i-shaft bearings, new cryo shaft, and oil pump and it still ground the teeth off the oil pump gear. this is the second time this happend but this time i made it 20 mi. am i doing something wrong?
shelby3322 is offline
Old 07-02-2009, 09:26 PM   #2
Re: oil pump help needed
Administrator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 119
What belt tension are you running?
Cory Hedin
I have a running T3 car! Woot Stock head for now 12.3@111 low boost :evil:
-87' Daytona Shelby Z W/ T tops <----Now broken.... It never ends. :(
bansheenut420 is offline
Old 07-02-2009, 10:00 PM   #3
im not sure, ive been askin on here of where to get a tool and i never got a reply
Old 07-02-2009, 10:16 PM   #4
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Feedback: (6)
spx miller special tools has them.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 07-03-2009, 02:57 AM   #5
alright. is that what my problem is?
Old 07-03-2009, 03:00 AM   #6
Feedback: (38)
Images: 201
likely.
Clayton-MFS is offline
Old 07-03-2009, 03:08 AM   #7
did i find the right one, that was $384?
Old 07-03-2009, 08:24 AM   #8
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
probably not! here is a pic of mine for reference............
rx2mazda is offline
Old 07-03-2009, 09:49 AM   #9
Super Moderator
Rick's Avatar
My Ride: SPiRiT R/T& IROC R/T
Engine: 2.2L TIII
Feedback: (9)
Images: 94
The number to SPX is 800-345-2233.
I bought mine off the tool truck. It took about a week to get it.
Rick Mosley
President: Florida Shelby Dodge Auto Club www.flsdac.org or www.flsdac.com
1984 Shelby Charger - Garnet Red/Auto
1991 SPiRiT R/T - White/no options
1992 IROC R/T - White/factory reliability test vehicle
"If Chrysler isn't the performance company, then I'm Joe Isuzu." - Lee Iacocca
Rick is offline
Old 07-03-2009, 10:01 AM   #10
My Ride: 87 Shelby Charger
Feedback: (7)
20 minutes WOW
how tight are u making that belt?? lol
ive roasted 2 shafts in my motor as well....on #3 and this one seems to be holding, it hasnt skipped teeth yet. what year I shaft/pump r u using?? are they the high volume ones????
uumm dontk now what else to tell ya....20 minutes just seems way too fast even if the belt was overtightened. maybe the machining was sloppy n the bushings are seating tight?
Juggy is offline
Old 07-03-2009, 12:40 PM   #11
Bye.
the.palmetto's Avatar
My Ride: WS6
Engine: 5.7 LS1
You said AFTER your rebuild, and then, it STILL ground the teeth off. You didn't specify, but does that mean it also happened BEFORE the rebuild? If so, how long had it been driving like that before the gear failed? If it happened before the rebuild, then you can rule out the machining for the bushings as the culprit. If it doesn't turn out to be belt tension I'm curious what else it could be.
the.palmetto is offline
Old 07-03-2009, 12:44 PM   #12
glhs727's Avatar
Feedback: (18)
Tom,
If you need the tool, call us next week, I'll lend you mine.
later,
Cindy
Your FWDperformance Team
281-288-4411 or 281-642-3878
glhs727 is online now
Old 07-03-2009, 03:56 PM   #13
Originally Posted by Juggy View Post
20 minutes WOW
20 miles
Old 07-03-2009, 04:23 PM   #14
yes it did happen once before, right after i rebuilt it the first time. im not sure how long it ran, cuz i was triing to get it to run right, but when i fixed the problem probly like 2 mi. it was probly about the same amount of time though. i guess it could be the tension, i dont have a gauge
Old 07-03-2009, 04:24 PM   #15
what should the tension be?
Page generated in 0.20863 seconds with 9 queries
