Old 07-04-2003, 10:21 AM   #1
Unhappy 2.2 TIII 16V swap into a P-body
Hybrid Booster
Hi all,
I know that many guys like Dave St-Louis and Cliff Ramsdell already done the Lotus TIII swap into a P-body (Dave) or a K-body (Cliff).
The old 2.5 T1 (actually TII specs) in my '89 Shadow is getting tired and I have a nice 16V TIII A-568 setup w/ 77k miles running fine.
I know I'll have to swap the A-520 shifter and cables for the A-568 setup. I already have a custom front-mounted IC and I'm not affraid of doing some fabrication to make everything fit.
What are the biggest issues of this swap? What I'm really affraid of is the wiring harness I'll have to swap the '89 SMEC and wiring harness for the '91 SBEC and TIII harness...
My question is: How hard is it to make the '91 TIII underhood wiring harness work with my '89 P-body in-car/dash harness?? I know I'll probably be able to make the car run but it would be nice to get some data to the dash and some power to the rear brake lights...
Any information is welcome
Thanks,
Pascal Blouin
PoOh is offline
Old 07-07-2003, 01:01 PM   #2
Unhappy
Hybrid Booster
Hmm... I'm not the only one freak enough to make a 16V P-body??
Anybody been there / done that?
TTT
Pascal Blouin
PoOh is offline
Old 07-07-2003, 01:14 PM   #3
i had a t3 motor i was gonna put in my csxt.you need to splice the r/t harness into the p-body harness.you need the computer also.then everything should fit right in i cant remember its been awhile sence i was gonna do it and there was some guy on here who helped me out
csxt#10 is offline
Old 07-07-2003, 01:47 PM   #4
Hybrid Booster
Actually an easier way is to find a P Body VNT harness (SBEC) and use it. Neil Emiro did this years ago (TIII VNT). YOu could probably use the R/T SBEC stock and except for a few pins being out of order it should work. Neil had a large VNT turbo on his car so he used a reprogrammed VNT SBEC and a cam mounted dist to run it.
DOHCRT is offline
Old 07-07-2003, 02:38 PM   #5
Hybrid Booster
Isn't there a lot of difference between a 8V-car SBEC wiring harness compared to a 16V-car SBEC wiring harness?
Like the DIS ignition, cam sensor and crank position sensors?
Pascal Blouin
PoOh is offline
Old 07-07-2003, 03:14 PM   #6
yeah, those are diff.. but neil used a distributer so he could use all 8v wiring. Im sure he had to lengthen/shorten some plugs since the TPS and AIS are in the front on the 16v, and so forth
i would guess if you want to use the 16v's DIS, use a 16v harness. If you want a distributer, use an 8v
FearThe4Doors is offline
Old 07-07-2003, 04:45 PM   #7
Thumbs up
Hybrid Booster
Well, since I have a complete R/T parts car with a running engine (I start it once a month just to be sure it's a true 16V and not only in my dreams...), I'll transplant every single thing I can find under the hood.
So I'll be using the stock R/T DIS ignition and wiring harness... spliced to feed my old Shadow dash and lighting system.
...hmmmmm... 16V lightweight P-Body :big grin:
Pascal Blouin
PoOh is offline
Old 07-08-2003, 02:29 AM   #8
what sucks.. is the P's are only like 100-200? lbs lighter than a big ol' Spirit. Unless of course you're introducing Mr SawZall to the car
Old 07-08-2003, 08:52 AM   #9
Cool
Hybrid Booster
Well I already introduced Mr. Fiberglass and Mr. NoRear Seats to my P-Body...
...Mr SawZall is the next guest on the list... He'll bring his friends: NoSpare TireWell and NoBumper SteelBeam. Mr. Lexan will come later to the party. :big grin:
Pascal Blouin
PoOh is offline
Old 07-08-2003, 09:13 AM   #10
My Ride: mostly mopar
a P body weighs 2800 lbs? What a fat ass ,thought they were lighter than that.
BLUEBALL is offline
Old 07-08-2003, 02:05 PM   #11
P-Body weight
Hybrid Booster
They are lighter than that. The curb weight for a 2-door P-body is around 2600lbs...
( http://auto.consumerguide.com/auto/u...fm/id/2027.htm )
Pascal Blouin
PoOh is offline
Old 07-08-2003, 02:21 PM   #12
My Ride: '02 Infiniti G20
Engine: SR20DE - 2.0 Litre
So another R/T sacrificed to the speed ***s........
Shame on you..... unless the rest of the car is trashed.....
and I hope it's not silver
From what I am reading it really sounds like a hybrid will be cheaper and easier to maintain in the long run......
H Bomb is offline
Old 07-08-2003, 03:04 PM   #13
Unhappy No sacrifice here!
Hybrid Booster
Hey H Bomb...
My Spirit is dead.... front body panels are all crashed and the frame is bent from a front impact on the driver side . I had to "peel off" the radiator from the engine bay... my SBEC plastic housing is in pieces but the PCB was intact: Thank you "brown rubber goo"! "thumbs up
It's easier to swap the drivetrain than trying to rebuild the car. I'm not destroying any good R/T here... I'm just trying to save a TIII... and I hate it when people are destroying good condition cars to get parts. But since mine is crashed... I couldn't resist to a 16V P-body :big grin:
Anybody need interior/cosmetic '91 Red Spirit R/T parts? The car is in perfect condition from the front doors to the rear bumper and it only has 77k miles.
Pascal Blouin
PoOh is offline
Old 07-08-2003, 03:14 PM   #14
Too bad to hear another one is gone but since someone did the damage by all means PLAY! Did not mean to offend but I am a sucker for the R/T. "thumbs up
Or if you wanted a real sleeper swap the drivetrain into the early 90's Lebaron 4 dr with the Landeau vinyl top! 4 wheel discs, 5 speed and all.....I think that would be cool!
Travis:big grin:
H Bomb is offline
Old 07-08-2003, 10:13 PM   #15
i hope they weigh less! I heard once the P's are like 2800 and AA's are just over 3k :dunno:
Find Local Jobs | Per Insurance | Credit Reports | Mortgage | Rewards credit card
Page generated in 0.43015 seconds with 13 queries
