How did you "snap" a TII/TIII rod on a basicly stock motor? What was the cause of the failure.
You, like the others, did a FULL rebuild. Thats a LOT more variables then just a pump.
Plenty of us have used the Melling pumps with no issue. And they have been stressed WAY beyond what yours went through in 25 miles.
Facts:
*Its only happening on a few select TIII cars.(3)
*Only to people who are new to the cars.
*All of those did a full rebuild
*One of those 3 used there STOCK pump. And it failed.
*A sealed power pump has failed, a factory installed pump reused after a rebuild failed, and a Melling failed.
*TONS of TI,TII,TIV cars are using the same pumps with absolutely no issue.
*Jackson has more TIII's sitting in his garage running fine with these pumps, then the total number that have failed.(Im a little jealous of that.
Leads me to believe that it isn't an issue with the pump itself.
But one question. Are the pumps seating right on the boss in the block?
There is a radius in the block that is VERY close to the pump. I always clearance mine when I port the oil pump hole. I think Melling actually warns of this on the literature that comes with the pump.
