Old 07-19-2003, 03:29 AM   #1
G-Valve nightmare
I am having the hardest time bleeding out my 92 Spirit R/T please can anyone help I get a max boost of 10 or 11PSI because of the Seven Pound Spike.
Help!! Please !!
Dave Jr is offline
Old 07-21-2003, 09:29 PM   #2
Re: G-Valve nightmare
Help!! Please !!
Hi Dave,
The #1 cause of boost spiking 7psi is hitting your head with a hammer multiple times. It makes your eyes cross funny, and makes the boost guage look like it's reading higher
Actually ... just make sure that your source of intake manifold pressure is unobstructed, and keep the vent hole kind of small, and that should be about as good as you'll get it. Make sure your G-valve is clean and not leaking from dirt ...
A good place to start is to adjust the wastegate actuator arm length. I've found that with the stock turbo, if you're shooting for the 14-18psi range, adjust the arm tight enough such that your minimum boost (intake manifold vacuum directly to the actuator) is about 9 or 10 psi through the medium RPMs. Go tighter if you're running higher boost than that. It will anti-creep in the higher RPMs, that's life with a stock turbo on an R/T ...
Keep tinkering, you'll get it right ...
Dan Culkin
Dan Culkin is offline
Old 07-24-2003, 06:08 AM   #3
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
In addition to wastegate arm length, if you have a stock BOV make sure it isnt leaking.
I like my wastegate arm on the tight side, I shorten the arm until I have to pull against the wastegate spring about the length of the hole(3/16). The TIIIs run alot of back pressure and tend to force the flapper open prematurely.
good luck
wallace
mopar2ya is offline
Old 07-25-2003, 12:17 PM   #4
Boost adjusting problems
I have a similar problem with my 92 R/T TIII. With the stock setup it would boost great to about 12psi then immediately drop to 7psi. I put a G valve on and adjusted the boost to 14-15 psi and now it immediately drops to 10psi boost. What’s going on? I’m running go fuel the motor has been completely rebuilt 2500 miles ago. Also I’m at 5800 feet altitude so I don't think I am detonating nor do I hear any.
scaltered is offline
Old 07-25-2003, 01:22 PM   #5
mopar2ya's Avatar
Engine: 2.2 TIII
If your knock sensor is working correctly you wont hear any knock, but you will feel the timing being retarded.
As far as you boost drop, I need to know how your grainger is installed. It needs to be in a line(larger the better) from the manifold. I tee'd directly into the line from the manifold to the brake booster. You want the grainger lines to be as close to the wastegate as possible. I Tee'd in right before the brake booster, then ran a short line into the G-valve and another line out of the G-valve twards the wastegate can. Before it gets there I tee'd it again, one goes to the wastegate the other has the restrictor bleeding to atmosphere.
I hold 20 psi just fine with about a 1 psi spike.
good luck
wallace
91 spirit r/t 12.72@110.888 mph
mopar2ya is offline
Old 07-25-2003, 05:16 PM   #6
As I mentioned in my prior reply it drops boost from 12psi to 7psi in the stock configuration, no gainger installed. Did not know if there was some sort of mechanical bypass in the wastegate actuator can that drops pressure above 12 psi to 7psi or what
Old 07-26-2003, 03:39 AM   #7
mopar2ya's Avatar
Engine: 2.2 TIII
theres no mechanical bypass. The above mentioned posts more than likely contain your solution.
mopar2ya is offline
Books | Loans | Mortgage | Loan | Secured Loans
Page generated in 0.51177 seconds with 13 queries
