My experience with the Holset HE351CW - Page 3 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > Turbo III
Old 11-06-2012, 11:45 AM   #31
Re: My experience with the Holset HE351CW
Level 4 Supporter
My Ride: 87 SHELBY DAYTONA Z
Engine: 2.2 T2
Feedback: (7)
lancerman23 is keeping the peace
Originally Posted by [X]treme R/T View Post
doesnt really matter cuz once air is compressed it heats the piss out of it anyways.
i have dual 10gph alky injection nozzles, so it really dont matter, the air charge is gonna get frozen
k so i hear more and more guys are using alky injection rather then water meth?
why is this? pro's n con's to either or both?
lancerman23 is offline
Old 11-06-2012, 12:02 PM   #32
[X]treme Aggression
[X]treme R/T's Avatar
My Ride: Spirit R/T
Engine: T3, Alky+Holset he351cw
Images: 4
[X]treme R/T is keeping the peace
alcohol =/= methanol
i run pure VP M1 methanol vs some people mix it
i run pure cuz its just better in general to prevent preignition / detonation and keeps the egt's in check better
cuz when compressed and sprayed in its pure form, methanol can get to around -150 degrees F. lowering IAT's - intake air temps alot.
so not only do you have the meth molecules cooling the cylinders when they contact the valves / head/ cylinder walls / piston heads, you are sending a lot colder air into the motor which helps with overall cooling.
and the colder the air is, the more dense the oxygen gets which = more vroom vroom :P
[X]treme R/T is offline
Old 11-06-2012, 01:48 PM   #33
Level 4 Supporter
Engine: 2.2 T2
Feedback: (7)
from some reason i seriously thought the two were different!
thanks for the input!!
Old 11-11-2012, 09:20 PM   #34
Level 1 Supporter
My Ride: 90 VNT, 92 Iroc R/T
Engine: TII,TIII,TIV many Tona's 2.2 2.5
Shredder is keeping the peace
Do you guys have a line on where to buy a new He351cw for a fair price,are there other mods that should be done to the turbo itself to. Like ported compressor side, or coatings needed? Thanks
Shredder is offline
Old 11-11-2012, 10:36 PM   #35
[X]treme Aggression
My Ride: Spirit R/T
Images: 4
you wont find a new one for under 1k.
your best bet is to get a low mileage one out of a wrecked 2004.5-2007 cummins ram for 3-500$, thats what i did.
Old 11-11-2012, 11:58 PM   #36
Level 1 Supporter
Guess I'm wondering if there's anything else people do to the he351 to optimize any other aspect. Do you guys all generally run a used holset without having to re-build it etc?
Shredder is offline
Old 11-12-2012, 07:37 AM   #37
wallace is keeping the peace
Not sure if this is a real Holset but BAE has them for around $600.
BAE Turbo Systems Inc. - 4036836
wallace is offline
Old 11-12-2012, 08:58 AM   #38
[X]treme Aggression
My Ride: Spirit R/T
Images: 4
i didnt rebuild mine at all and got for 400$ shipping included
put about 4000 miles on it it so far and its perfectly fine.
they are capable of up to 45-50 psi of boost but anything over 32psi is out of their map. so if you are gonna be running less then 30psi, the lifespan will be pretty much indefinite as long as you keep on the oil and filter changes
Old 11-12-2012, 12:20 PM   #39
Level 4 Supporter
Engine: 2.2 T2
Feedback: (7)
is it possible to run a holset on an 8v?
unfortunatly im selling my R/T and i still have my mint 87 tona z .. that would be awsome to put this on.. IF it would fit.
Old 11-12-2012, 12:50 PM   #40
Daytona Junkie
yes
Old 11-12-2012, 02:05 PM   #41
Level 1 Supporter
Thanks, have you ever dealt with BEA before. I'm interested in buying a new turbo, and probably will. So anymore insight or buyer options are appreciated
Shredder is offline
Old 11-12-2012, 02:55 PM   #42
I bought the rebuild kit for my hy35 from them it appears to be of good quality. The thrust and bearings are brass. Also includes two different size buttons as a few of the hy35's have an odd size one in them. Give them a call they were really nice and very helpful when I ordered.
wallace is offline
Old 11-12-2012, 03:55 PM   #43
[X]treme Aggression
My Ride: Spirit R/T
Images: 4
never heard of "BEA" ><
Old 11-12-2012, 05:18 PM   #44
Level 4 Supporter
Engine: 2.2 T2
Feedback: (7)
super cheap!! can't wait to throw one on the ole 8valver!
Old 11-12-2012, 09:09 PM   #45
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
rx2mazda is keeping the peace
Well, no turbo's lifespan is indefinite, regardless of care. 4K is not a lot of miles for a turbo unless it's from China.
That said the He351 is a great turbo! You should definitely open up the WG hole in the turbine so that you can control boost better and get less than 18-20psi. The stock hole is way to small for our application. I believe Jackson has a Jig set-up just for this purpose. If I did another He351 I would definitely cut the 90 elbow off the compressor and reclock it like Shadow did on his CLients TIII L-body.
rx2mazda is offline
