10-26-2012, 07:02 PM
Re: no start, help!
Garrett Booster
My Ride: 93 iroc rt 93 iroc
Engine: 2.2 turbo III, 3.0 V6
No problem! Also check your battery terminals, where there wire goes into the lead terminal. They corrode inside, causing a voltage drop. Everything in the car may work but when you hit the key you get nothing. One more thing to check is your ignition lock cylinder, they break inside and wont give you start only acc and run. If it feels weird when turned all the way to start it may be broken.
