01-22-2013, 12:39 PM
Re: arp head stud over torque
TD Extreme User!
Engine: 2.5L TIII DOHC
I go 95 ft/lbs.
YOU MUST make sure the studs don't bottom out in the block, if you used the Honda studs, you MUST tighten them down then back off a few turns, then when installing the nuts, HOLD the stud from moving otherwise it turns back in and will bottom out and you won't get the proper torque and you can crack the block.
