Old 05-01-2004, 04:08 PM   #1
Decided to check the lifters today....
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I decided to check the lifters on my Spirit R/T today. I removed the intake valve cover first. Everything looks OK as far as I can tell, except most of the plastic retainer rings on the lifters were either missing or broken.
Then I removed the exhaust valve cover. Here is where things get BAD. A rocker arm for one of the #2 exhaust valves was completely busted. The roller and lifter assembly were GONE. I couldn't find the pieces anywhere. There is also a nice gouge in the cam lobe, but not too severe. What do I do now???
I will post pics of the rocker arm carnage later today.
iTurbo is offline
Old 05-01-2004, 04:13 PM   #2
Also, the engine makes great compression and oil pressure. The only noise the engine made was from the valvetrain, which is why I decided to check the lifters today. Car doesn't smoke at all either.
I think somebody (previous mechanic) found out what was wrong, but then found out that TIII valvetrain parts are practically impossible to get, and decided to put it back together anyway. I can't find the lifter, roller, or any loose metal under the valve cover.
{EDIT} I went to www.newmoparparts.com and they list the intake and exhaust rockers for the TIII engine at $115.20. Are these really still available? If so, is that price for one or all eight?
iTurbo is offline
Old 05-01-2004, 05:50 PM   #3
My Ride: 91 Spirit R/T
Engine: 2.2L T3
The price of $115 is for a single rocker arm, although if memory serves me right it also comes with a new lifter.
RJ138 is offline
Old 05-01-2004, 06:04 PM   #4
How do I know if I'm getting the left or right side rocker arm? There are two different exhaust rockers; left and right.
I noticed that there is a # stamped into the side of the rockers:
Left rockers:
F-46910.1
LH 06
Right rockers:
F-46910
RH 06
iTurbo is offline
Old 05-01-2004, 06:24 PM   #5
And one more thing....what are those little metal discs and where do they go? I found three of them after removing the exhaust rocker shaft....
iTurbo is offline
Old 05-02-2004, 10:27 PM   #6
They go in the tip of the rocker and the lifter rides on it. There are 3 small cuts on them also, I forget off hand which way they are supposed to be installed.
Turbo3IROC is offline
Free Myspace Comments | Car Loan | Debt Help | Share Prices | Mortgages
Page generated in 0.32431 seconds with 13 queries
