where to hook up signal wire for aftermarket tach? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 9 Old 12-04-2004, 03:29 PM Thread Starter
Garrett Booster
well just like the title says, i am wondering where the signal wire on my aftermarked tach hooks up to on my 91 spirit r/t since it has the dis ignition system. my factory tach is acting up and its time for an upgrade!
thanks
Jerry
sandmcrew2 is offline
post #2 of 9 Old 12-04-2004, 03:51 PM
My Ride: 89 Daytona ES
Engine: 2.2L TII
negative lead on the coil
diabloed is offline
post #3 of 9 Old 12-04-2004, 07:01 PM
My Ride: 93 Dodge Shadow R/T
Engine: 2.2 DOHC Lotus
The easiest place will be the wiring going to the instrument cluster. The TIII uses DIS so your options here are buying an MSD Tach adapter $50 to combine the two leads from the coil pack or just use the filtered tach output from the PCM. You will need to hook into the Grey/Lt Blue wiring going to the instrument cluster. This is the Tach output wire from the SBEC.
Shadow16V is offline
post #4 of 9 Old 12-05-2004, 09:04 AM
My Ride: 1987 Reliant Wagon
Engine: 2.5 TIII
Jerry,
The only way to make an aftermarket tach or Shift light work with a TIII is to use Autometer part number 9117. It ties into the positive feed wire to the tach and converts a signal that is useable by a standard tach or shift light.
I used one of these in my wagon and you can't use the factory tach feed, wrong signal and since the car has a DIS ignition the coil has two negative sides and the tach will read incorrectly.
Hope this helps.
Cliff Ramsdell
VP New England SDAC www.sdacne.com
'91 Spirit R/T 2.2 TIII, 568. SOLD
'86 GLHS 065 Going back to stock "appearing"
'86 K-Car Wagon 2.5 TIII, 568.SOLD
Mopartek@aol.com
http://www.members.aol.com/mopartek/home.html
thanks
Jerry
Cliff Ramsdell is offline
post #5 of 9 Old 12-05-2004, 09:43 AM
Cliff, that's funny as I'm running an autometer Tach in my Shadow(TIII Powered) simply by hooking into the Factory tach feed to the dash. It matches the Engine RPM displayed on the DRBIII Perfectly. I'm also using the same wire on my '98 Neon R/T for a Shift light and no problems there either. Why do you say it's the wrong signal?
post #6 of 9 Old 12-05-2004, 09:53 AM
http://hp.autometer.com/techtips/faq...nd_beyond.html
Scroll to the bottom of the page, the information for the Neon works with the TIII.
The tach I'm using is the automter 6864. It's at the top of the page here.
http://hp.autometer.com/products/sil...ack_tachs.html
No problems for me.
post #7 of 9 Old 12-05-2004, 11:52 AM
Engine: 2.5 TIII
I was using the autometer shift light module and it wouldn't take the signal from the factory sending source so I used the adaptor.
If you have it working maybe it's the differance in the lamp module and the tach and I'm sorry for sending off false information.
Cliff Ramsdell
post #8 of 9 Old 12-05-2004, 12:03 PM
It may be a difference between the tach and the shift light module. Not really sure there. If it were not such a Pain I'd remove the Shift light module from my Neon and try it in my Shadow. I just hate to see someone spending money when they don't need to.
post #9 of 9 Old 12-05-2004, 01:53 PM Thread Starter
Garrett Booster
So is there a way to wire it without having to take the dash apart to get behing the instrument cluster? I dont mind spending $50 to make it work correctly. Thanks for the replies.
Jerry
Human Verification
