11-28-2007, 01:00 PM
#19
Re: vnt help?
My Ride: 90 Vnt Comp. Shadow
Engine: 2.2 Turbo IV
I did a little research and sounds like Mahle is the best cast piston to run if you are not going to run forged, that is what the OEM pistons are. They should be fine if you are running a stock setup. Forward motion sells JE forged, venolia forged are also great, even
Trw forged but you are talking probably $700.00++ Not really sure what everybody is running in their motors, my 90 vnt Shadow has the stock pistons no problems yet, running 15lbs boost.
