VNT Help for VNT cars
Old 08-10-2009, 09:28 PM   #1
VNT oil drainback tube. I think I might want to buld one
My Ride: 90 daytona shelby
These babies have been unobtainable for 10 or more years now.I kinda rigged one up on a lathe out of solid aluminum years ago but never liked how it fit. Since I never actually had a drainback tube to copy, I was wondering if someone could post a pic and a few dimensions of one to copy. I am really interested in the overall tube length, its ID and OD and if its bent or straight or what? I am really not equipped to go into limited production, but I could build a few if I can build it easy, cheap and accurate, any help would be vastly appreciated.
rocks90vnt is offline
Old 08-10-2009, 10:23 PM   #2
Re: VNT oil drainback tube. I think I might want to buld one
Daytona Junkie
midnighttoker's Avatar
My Ride: 87/92 Daytona/IrocRT
Engine: 2.2L TII/TIII
Feedback: (38)
Images: 12
i think you can get them from FWDperformance
midnighttoker is offline
Old 08-11-2009, 06:19 AM   #3
NAJ's Avatar
Feedback: (7)
Which tube are you referring to?
I only had the head and turbo out once(1 1/2 years ago) and all I seem to remember was a straight nipple on the turbo and one on the block with an oil/heat resistant hose in the middle.
Seem to remember the hose being a PITA to get back on.
Old 08-11-2009, 03:41 PM   #4
I have asked Cindy at fwd performance before no luck there. I found a pic of what I need, If anyone can get me the pipe ID and OD where it meets the turbo, I can probably fudge the rest.
Old 08-11-2009, 03:42 PM   #5
Oh yeah, it is the pipe on the left
Old 09-30-2009, 11:00 PM   #6
My Ride: 2000 VW TDI w/VNT25
man was this a PITA on my VW TDI. I used a custom drain back fitting that I made for a K04 turbo which has two holes. I found an rubber o-ring that fit snuggly inside the turbo fitting and then bolted it down tight with one bolt. It holds the oil pressure no problem. But, I had oil coming out the exhaust. Too much restriction and too much pressure. So, I made a restrictor for the feed line and still oil out the exhaust. So, I tried the stock VW fitting since the fitting I had made could not be modified. Still too much restriction. So, I made a new pipe with 1/2" ID and still oil but not as bad. And finally I made one with 5/8" hose and all is good.
Garrett sent me the layout print for the stock turbo fitting, but what I have for now will work. If anyone needs the print of the original design, please let me know.
garrettpf is offline
Old 10-01-2009, 08:05 PM   #7
Yeah, If you have the print available, I sure would like to see it
Old 10-02-2009, 08:33 PM   #8
here it is. I hope this is what you are looking for.
Old 10-02-2009, 08:34 PM   #9
need to have 5 posts in order to have a URL in reply :(
Old 10-02-2009, 08:35 PM   #10
and I have to wait 20 seconds between posts LMAO
Old 10-02-2009, 08:40 PM   #11
WOO HOO, 5 posts... and here it is ;)
http://meganjoy.org/TD2501FLANGE.DOC
Old 10-03-2009, 10:02 PM   #12
Thanks for the pic. I can now build the flange the way garret intended!!!
Old 10-04-2009, 09:34 AM   #13
Oddly enough, I go by Garrett P. since I used to do chiptuning for UPsolute and people would call me thinking I was the real Garrett lol
Post up a pic if you build one.
Old 10-11-2009, 11:58 PM   #14
Holset Booster
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (25)
Images: 1
I think I might have one of these in my pile of VNT parts still......
lotashelbys is offline
Page generated in 0.21390 seconds with 12 queries
