VNT Help for VNT cars
Old 10-28-2004, 10:11 PM   #1
braided line problems
My Ride: 2 89 Daytona Shelbys
1/4: 13.600
I have just bought a braided turbo line kit for the vnt.Has anyone did this?Only 1 of the 3 lines is matching up right.I`ve tried a couple different ways.Is the factory line on the back side on the bottom supposed to screw into what`s already in the block? The coolant line is way off where it connects to the turbo ,I`d say 6 `` and going in a different direction. I compared it to my t2 set and it`s different. Travis
GLHSHELBY is offline
Old 11-10-2004, 10:30 AM   #2
My Ride: 90 Shadow ES VNT
Engine: 2.2l 135 CI
I would get with whomever you purchased the lines from. When I purchased mine from FWD over a yr ago, it was missing fittings and was too short. I had to have the oil return on the front of the block brazed/welded in. The brass fittings on the rear of the turbo need to be taken off completely to work with the lines.....
90DodgeVNT is offline
Old 11-30-2004, 11:59 PM   #3
1/4: 13.600
I had them modified to work better than what they were designed for.I added enough clearance on the one from the thermostat that it`s easy to tighten now. I spent about $40 but I believe it`s better than the original set,of course part of that was modifying them to fit.
Old 12-01-2004, 01:34 PM   #4
re coolant line
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
I had to add a right angle fitting on a TII conversion with oversize wastegate. It looked like it needed 6" till my auto parts guru pulled out a fitting that made a perfect fit to run the line AROUND the LEFT side of the the actuator.
looneytuner is offline
Old 12-01-2004, 11:03 PM   #5
I had to do the same thing on my line. And I thought I was the only one having this problem! Mike
Daytona90Shelby is offline
Repair Bad Credit | Bad Credit Mortgages | Electricity Suppliers | Compare Mobile Phones | Myspace Layouts
Page generated in 0.30480 seconds with 13 queries
