VNT Help for VNT cars
Old 12-02-2004, 08:34 PM   #16
My Ride: 2 89 Daytona Shelbys
1/4: 13.600
I plan to use a bov on my top hose just because my bottom one is metal now and I have the top one made up already.
GLHSHELBY is offline
Old 12-02-2004, 10:14 PM   #17
My Ride: 90 Lebaron GTC
Engine: 2.5 TII
Yeah Illusional, and sometimes they blow up. LOL. Mine cracked apart interanlly and caused the turbo to overspin and fail. Sometimes upgrading a part is not just for performance. The life of a turbo that costs double that of TII is a great thing to save.
crazyace is offline
Old 12-03-2004, 05:56 PM   #18
Only the '90 VNTs got a blow off valve from the factory. The '89s didn't.
Shelby VNT is offline
Old 12-04-2004, 09:33 PM   #19
1/4: 13.600
I didn`t know they didn`t have them. See I learned something today.I quess I`ll put the greddy type r bov on my csx that`s been laying around my garage for 2 years.
Old 12-05-2004, 11:15 AM   #20
My Ride: 90 CS VNT
Engine: 2.2L TIV
A BOV causing a Turbo To Overspin? how is that possible? If your VNT fail's.. I'll give ya mine.. Its going in the trash anyway!...
IllusionalTA is offline
Old 12-05-2004, 11:52 AM   #21
A leaking BOV, or a leak anywhere in your plumbing can lead to turbo failure. In the event of a leak, the turbocharger wastegate will not open (or the vanes on a VNT will not open) because max boost is not easily or ever obtained. The turbo will continue spooling to try and achieve the max boost, eventually over spinning. This could lead to failure. In the case of a VNT, it's already spinning very fast. The Garret VNT-25 was designed for a max displacement of 1.8 liters, but Chrysler went ahead and used it on their 2.2 liter engines. That's not bad in itself, but when you get guys cranking up the boost more, it spins the VNT ever faster. More then 15 psi will destroy the seals. So, yes, it is possible to over spin a turbo, either due to a leak, or plain stupidity.
Old 12-07-2004, 01:19 AM   #22
Engine: 2.5 TII
You forgot one other point Shelby VNT, It could also happen because of both. LOL. I had mine trying to push 14psi then the BOV went and never really did quick sounding off. It just sounded different, being old itself it did not take long after that before it went.
Illusional,
I am hoping to never need another since I am leaving it at stock boost. I doubt there are more than 25 - 35 Drop top Lebarons left out there with the VNT motor and I want mine to stay intact.
crazyace is offline
Old 12-07-2004, 12:23 PM   #23
My Ride: 90 CS VNT
Engine: 2.2L TIV
Now that sounds viable!.. My VNT is stock and i use it as a beater.. although it's suppsoedly one of 31.. THe body is falling apart..
Cheap Car Insurance | Debt Help | Xecuter 3 Mod Chip | Myspace Layouts | Loans
Page generated in 0.42335 seconds with 13 queries
