11-28-2004, 02:08 AM
My Ride: 2 89 Daytona Shelbys
1/4: 13.600
Originally Posted by crazyace
The vacuum supply is simple. that one should come from that multiple outlet vacuum splitter on the intake manifold (the four into one). The Baro-read solenoid is the little valve right next to your MAP sensor. The vacuum should go to the baro-read and then on to the MAP sensor.
I found it tonight on the 4 into 1 splitter.It just came out and wasn`t broke. I got the car running but I still have a boost problem just not as bad.Any time you go over 4-5 lbs it just cuts out. I `m sure it`s the vnt solenoids plus it`s getting code 34 which is solenoids. I have another set of used solenoids but it`s the 3 that are together. A friend of mine told me that it`s most likely the solenoid right behind the 3. Does this sound right?? I do fell better,the car runs pretty good now beside the boost problem.
